Question about Shure WIRELESS MIC SINGLE ANTENA MIC Microphone
Scrah noice on speakers when the persons move around.is pg14/pg185
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
1) Try changing the channel to see if this has any effect.
2) Make certain the receiver is out in the open and visible from where the talker is standing.
Posted on Oct 05, 2010
Buzzing noice in speaker i think it is the woofer
I had the same problem, check the pine connexion it's probably the problem, mine was cut in half and do short-cut that produce that noice.
Jun 27, 2011 | Creative Technology Kwong Quest Benwin S...
Creative Gigaworks T20 (series I) Left speaker just producing noice, until I turn the Bass knob counterclockwise towards "minus" - then there is sound in the left speaker but even more noice...
The problem that developed with my Creative Gigaworks and other is that occasionally it would not play at all. When the problem occurred, I could eventually get it to work again by turning it on and off several times. I opened up the powered unit (the Right speaker with the controls and found that the wires were really crammed in there, such that a white ribbon wire connector on the bottom was straining to the point of where it was slightly cracked. While playing audio through it, if I touched that wire ribbon, the sound would cut out. So I adjusted the wires slightly to relieve any tension force on that connector and it has not had the problem since. I would open up that unit and check for a similar poor or strained connection. To open the unit, carefully pull off the fabric speaker cover straight off, remove the 4 rubber inserts in the top 4 holes, and remove all 6 philips-head screws in those deeply recessed holes.
Jun 03, 2011 | Creative Labs GigaWorks T20 Computer...
Scratching noice while the lense move out
My Optio S does the same thing but works perfectly otherwise. Don't worry about it.
Feb 24, 2010 | Pentax Optio 550 Digital Camera
Need help recording in stereo (sound only coming from L spkr)
You generally need two microphones to record in stereo. If you have only one microphone to use, you have to make sure that the pan pot for the channel you are plugged into is set in the center of its range.
Apr 23, 2009 | Shure PG185 Microphone
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Z2300 logitech
This is common in these type speakers but usually comes from poor grounding in the computer or in your outlet.
connect the unit to another outlet and run from a walkman or some portable player and see if you get the same buz. Work backwords from there by plugging into the same plug and unpluggin everything else. You will probabbly find something in/around your outlet is causing the noise.
Jan 20, 2009 | Logitech Z-2300 Computer Speakers
Can't hear without handsfree, beeps
Hmm..did you try the customized profile so you can set it on the loudest mode? and also have you noticed if your phone makes any other noice like when you move around the menu or type a text messege? does it play music on the speaker? Try all possible ways you can think of that makes the phone create sound as a response. And last thing to do would be a reset.
  • Go to menu
  • Phone settings
  • Reset settings
Try this to bring the phone to factory settings, make sure you back up your information, like your contacts before, and good luck.!
Dec 13, 2008 | LG KU990 Viewty
Problem with speaker phone
This is a known issue(my phone does the same), I suggest that you keep the phone close to you self when you use the speaker phone as the phone does not have noise callenation feature on it, due to which it absorbs outside noice also.
Jan 28, 2008 | Motorola Mobility ROKR E6 Smartphone
Noices
there are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Nov 06, 2007 | HP Compaq Presario SR2150NX PC Desktop
49 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
