Question about Hammer Drills
I have a masterforce 1/2" hammer drill and the chuck won't tighten-it's stuck open. Is the chuck shot?
    Habit-Forming:
    New Friend:
  • 121 Answers
Use a pair of stillson adjustable spanner .
adjust the spanner to go around the chuck then turn to close as it will ease off then ca use your hand as nornal
Posted on Sep 30, 2017
  • 22 Answers
SOURCE: Chuck tines on Ryobi Hammer Drill Are Not Engaging Uniformly
home depot replacement chuck i beleive you can also us a keyless chuck. they usually come with instructions. most have a screw at the inside of drill chuck.
tom
Posted on Dec 13, 2008
comax
  • 154 Answers
SOURCE: Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Posted on Apr 13, 2009
SRF518
  • 232 Answers
SOURCE: Skil 3/8 Hammer drill #6425 chuck ring broken in half
get a new chuck - thread is a 3/8-24 left hand thread
Posted on Oct 23, 2009
radar001
  • 1051 Answers
SOURCE: keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Posted on Feb 23, 2010
  • 16 Answers
SOURCE: bosch keyless chuck stuck
Make sure you try it in both directions.
Posted on Jun 11, 2010
Chuck stuck open on my psb700 re
not much can be done as the chuck is not specifically designed to handle hammer drill operations (they crack the scroll thread adjuster inside )
best get a new chuck and if you do a lot of hammering get a proper hammer drill that has a push in operation not an ordinary electrical drill with a hammer capability
Sep 09, 2016 | Bosch Drills
What is the Chuck Taper Size? MasterForce model # 240-0064 12" Drill press
Masterforce is no longer supplier of power tools, they are a cheaper line of Makita, and maybe craftsman.
Jan 08, 2016 | Drills
Lost the chuck for my master force 12" drill press where to get replacement part
[PDF]12" Drill Press - Menards
https://www.menards.com/main/store/...Tech.../240-0064.pdf
Menards12. REMOVE ADJUSTMENT TOOLS. Always make sure all adjustment tools are removed from ... Should any part of the drill press be missing, damaged, or any electrical component fail to ...... Use only MasterForceâ„¢ replacement parts. Use of ...
MasterForce 12" Drill Press Repair Questions, Solutions and ...
www.fixya.com > Forum > Drill Presses > MasterForce
Free expert DIY tips, support, troubleshooting help & repair advice for all Drill ... Lost the chuck for my master force 12" drill press where to get replacement part.
Lost the chuck for my master force 12" drill press where to ...
www.fixya.com/.../t23651560-lost_chuck_master_force_12_drill_press
Feb 24, 2014 - Lost the chuck for my master force 12" drill press where to get replacement part Where to get spare parts - MasterForce 12" Drill Press question.
Drill Press Parts & Coring Drill Parts ' Tool Parts Direct
Feb 24, 2014 | MasterForce 12" Drill Press
Chuck problem
If it is a keyless chuck, try resting the chuck on a wooden work bench, and with a dead-blow hammer aka: shot hammer, slant-strike the chuck in the unscrew direction.
Dec 10, 2013 | Dewalt 18 Volt Compact Drill Kit
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
Drill bit keeps coming loose
When the drill bit on a hammer drill keeps loosening up one of two things is happening. 1. The chuck is worn out and needs to be replaced. 2. The chuck is not tight enough before you start drilling. If you have the style of chuck that requires a key do not be bashful about using maximum force to tighten the chuck and move the chuck key from hole to hole and tighten it in each position. Joe
May 08, 2010 | Drills
Bosch keyless chuck stuck
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Drills Logo
301 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
