Question about Polaroid Televison & Video
How do I stop two Polaroid TVs from using the same remote?
I have two Polaroid TVs, a wall mounted one and one I am using as a computer screen. When I turn one on the other will also turn on and the remotes work on both, is there any way to stop this? One is a smart tv one is not.
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
  • 360 Answers
SOURCE: My Polaroid remote control won't work.
First we need to know if the remote is working. Heres the "secret" way to check a remote. Use a cell phone w/camera.
  • Set the cell phone to camera
  • while watching the camera screen and a known good remote, aim the remote at the lens and press a button (volume works well) on the remote (not a device button ie; sat,tv,vcr,etc). You should see lights turn on/flash. Now you know your camera can detect IR light.
  • Do the same again with the remote in question. If there is no IR light output, the remote is the problem. replace the batteries, ensure good battery contact, retest the remote.
If the remote is working then the problem is in the unit.
Let me know what you find.
Neat trick, huh? Please take the time to rate this.
clarkco
Posted on Feb 10, 2009
SOURCE: vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Posted on Feb 19, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
  • 3197 Answers
SOURCE: My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Posted on Aug 03, 2009
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Lost the remote to a 47in flat screen hdtv Polaroid need to change input
All the lcd tvs have Volume up/down, channel up/down, power button and input button integrated to it. check for it. may you will find it in left or right side or in the bottom. by using the input button you can chance the input .If the the key pad is locked then you have to have the remote to unlock it.
Feb 23, 2015 | Polaroid Televison & Video
How much does this TV weigh? Is it considered a 32" when mounting on wall or do you considered the entire diagonal at 38"?
The TDA-03211c weighs 39.5 pounds; however, I'm not sure if that is with or without the base. The shipping weight of the TV is 50.3 pounds. Most wall mounts use the standard screen diagonal measurement to determine what size TV it will support. So the 32" is sufficient information for choosing a wall mount.
I hope this helps.
Nov 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Need more codes for polaroid tv
Welcome to FixYa!
It actually depends on what kind of universal remote control you are using.
  • Philips universal remote codes for Polaroid TVs: 0819, 0918, 0914, 1503, 1215, 0504.
  • GE universal remote codes for Polaroid TVs:0182 0173 0133
Thanks for using FixYa.
Have a great day.
Jas247
Apr 20, 2011 | Televison & Video
How to setup my flat tv in the wall?
Any of the "big box" stores that sell large-screen LCD/LED/PLASMA TVs will also sell the wall-mount units.
Or, try 'www.eBay.com'.
Nov 14, 2009 | Samsung SyncMaster T260HD flat panel TFT...
No tv stand
Just about every LCD TV has a VESA adapter mounting section on the rear. Measure the size there (75mm 100mm etc), and check Wall Mart, Best Buy etc. for a mount. They are readily available.
Aug 24, 2008 | Polaroid FLM-2632 Television
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Sep 10, 2007 | Polaroid FLM-2011 Television
Polaroid 0722 Player
On most of the set top DVD players you use the monitor button or the remote control menu button to access the mode that flips the display (invert). The mode is for those who mount the units to the ceiling of a vehicle for rear passengers to view. You might have to have a DVD playing at the time or just loaded in the stop mode to access the feature.
Jun 08, 2007 | Polaroid PDV-0700 Portable DVD Player
Televison & Video Logo
26 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
