Question about Cell Phones
I cant seem to get nabers - Cell Phones
  • 3,498 Answers
What are nabers??? .....or nabbers or neighbors??
Posted on Aug 11, 2017
Golf 3 gti 2.0 8v
what year is the car?
Jun 23, 2013 | Cars & Trucks
I cant seem to get my mini's clutch to work i have replaced almost everything on it and cant seem to get the clutch working ? if someone might know way this is happaning please help
What do you mean it is not working?
You can not engage it?
You can not get it to Shift while running?
Have you Bled the AIR out of the Secondary ?
Does your System have enough Fluid?
Apr 08, 2013 | Cars & Trucks
My loop mobile sim has blocked and asking for puk code
You need to telephone your mobile phone service providers as they're the only ones who can give you the puk code.
Apr 21, 2011 | Health & Beauty
No spark on #2&3 plugs
Generally if two cylinders arnt firing side by side I would be doing a compressiom check and a chemical block test or sniff the coolant for the presence of Hydocarbons. If this car has the quad coil pak that bolts to the top cover it could be the coil pac. Very common problem for the grand prix 4 cylinder, I'm retty sure this car is the same setup
Aug 03, 2009 | 2003 Pontiac Sunfire
Wireless security
the WEP password is located on the label on the botom of your router. The WEP password prevents unotherize conecting to the network. If some one for example like your naber see your network and conects to but put in the wrong WEP they will not be able to use your internet.
Jan 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Can sen me serial naber a Nero 9 trial
Nero 9 Serial
9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A
Dec 31, 2008 | Ahead Software Nero 6.6 (600901) for PC
CPU Upgrade
Dear naber
The TOSHIBA Satellite 1135-S125 contains the
Intel 852GM chipset soldered on your motherboard (non removable) which is capable for speeds of 400mhz system bus. Actually what this means is that it capable of running your Pentium-M P4 2.4. so I would doubt a motherboard incompatibility.
The processor runs at the speed you state (1.2 GHz) in battery-optimized mode (1.2V core) (24/2multiplier) instead of its full potential when unplugged from the AC adaptor. I believe the speed remains like that even when plugged at the cable due to dynamic switching either at the BIOS or Windows. This means that the system is slowing down deliberately the CPU until a certain % and then it kicks in full power. (24x100Mhz=2400Mhz multiplier) (For heat purposes mainly,also increases the CPU life..so this is normal operation and you should not be worried)
Please download the utility cpu-z at the following link
http://www.cpuid.com/cpuz.php
and check what I am saying. It will be displaying the Ghz of the CPU realtime so you can see if when you start any benchmark if it kicks in with a higher multiplier and hence the 2400Mhz speed due to increased stress to the CPU.
Otherwise you may check your BIOS for power management options and switch them to Disable just for testing. (you should enable them back after testing in order to cut down the increased watt consumption)
Lastly if that does not help a Bios Update might be the only resolution. I have found this Motherboad BIOS update for you
ACPI Flash BIOS version 1.70 for Satellite 1130-S155 http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=521179&moid=430235&rpn=PS113U&BV_SessionID=@@@@1021980656.1206965091@@@@&BV_EngineID=cccdadedjmhfdeecgfkceghdgngdgmn.0&ct=DL&all_docs=false
This bios seems to enable support for CPU's at steps A2 which may be your chip. Unfortunately you did not state the BIOS revision so if it the V1.30 this bios will also add support for CPU's at stepping D1 as well.
Regards
If you found this info helpfull can you please rate the solution, Thats what keeps us going!
Mar 30, 2008 | Toshiba Satellite 1135-S125 Notebook
I forgot my security code
my nokia 5300 red music edition has a security code and i forget it now how can i unlock my password. my fone imei is 356959011065446
Dec 12, 2007 | Nokia 5300 Grey Cellular Phone
Cell Phones Logo
49 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
