Question about Canon Office Equipment & Supplies
How do I restore factory default settings on Canon Laser Class fax machines?
SOURCE: canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Posted on Apr 26, 2007
SOURCE: Reset Factory Defaults
I fixed the problem with no help from your service....as a matter of fact, I mailed the guy back that "helped" me online and heard nothing from him either.
Good thing Im resourceful.......$15 WASTED!
Posted on Oct 15, 2008
iservice
  • 318 Answers
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Posted on Sep 11, 2009
brett207
  • 231 Answers
SOURCE: My Canon Laser Class 710 fax machine is flashing a
You could be out of toner = new toner cartridge.
You could be out of paper = reload paper
You could have a printer problem, paper jam, door open, etc
get the printer part working.
does it print a report if you press the 'report' key?
Posted on Dec 07, 2009
SOURCE: How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Posted on Aug 03, 2010
Testimonial: "Thanks, that did it!"
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Jul 22, 2010 | Canon LaserClass 9000L Plain Paper Fax
Canon Laser Class 510 - Speed Dial
creat group dial then regester speed dial
Jan 15, 2010 | Office Equipment & Supplies
Delete Memory Canon Laser Class 7000
you can reset your restore default factory setting or by removing cmons of logic card .
Jun 08, 2009 | Canon MX300 Office All-In-One Printer
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Factory reset.
one of the menu option should say restore defaults
Aug 29, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
55 people viewed this question
old marine
old marine
