Question about LG Shine KE970 Cellular Phone
How do i get the attached blue tooth to work.
The radio in my 2012 Toyota Sienna XLE stopped playing and will not start back up. It gives a flash of sound when you turn on the key and then goes silent.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Sep 30, 2016 | Toyota Sienna Cars & Trucks
How do I get a blue tooth program for my garmin nuvi vehicle gps,the booth tooth is built in just no program for it .for me to use the device as a blue tooth other than a gps
You will nt be able to sue the nuvi 255w as a handsfree unit, the nuvi 265w is the unit that would support handsfree calling. And unfortunately there are no programs or attachments that can be purchased to make the 255w into a handsfree unit.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 255W GPS Receiver
Hi fixya, this rajendran from tamilnadu, i have acer 4736z. how to switch on blue tooth?. Pl help
If your blue tooth working normal just double click your blue tooth icon on screen to activated your blue tooth.
Regards
Feb 04, 2011 | Computers & Internet
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Don't have USB driver, how to transfer pictures from Nokia 7210 to Personal computer?
transfer your pictures from your nokia7210 via blue tooth.attach your computer via blue tooth dongle.connect through a code0000 on both the item.now you r ready to transfer your images
Aug 15, 2010 | Nokia Handsfree For 6020, 6101, 6102...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooyh not working
the blue tooth has a solution.
It is in two ways.
Either the the blue tooth is not pairing well with other devices,
or
The blue tooth is corrupted.
When pairing phones together, make sure you pair the phone properly before you can use the blue tooth with other phones, because if you don't pair properly with another device, you will not be able to send or receive any data.
If the blue tooth is corrupted all you need to do is to flash the phone, that is the only way to restore the blue tooth back to be working.
Have a nice day.
Mar 15, 2010 | Nokia N70 Cellular Phone
I have a sanyo katana , will all blue tooths work on this phone?
Most of blue tooth will work with this phone, but to be on the safe side. Go to blue tooth manufacturer website and check if their blue tooth is compatible with your device.
Nov 14, 2008 | Sanyo Katana® II Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
I have just bin an bought a bluetooth usb dongle with the instrlashion disk an it starts to install then it stops an askeds is to insert the disk but it isnt reading the disk an say to search the internt...
for installing the blue tooth , first insert the cd and run the setup don't attach blue tooth device at this time,
it will insall drivers, check continue any way option, after that plug in the blue tooth dongle, if again it will ask for driver check continue any way option, do it
how do you like the solution please rate it
Oct 14, 2008 | Computers & Internet
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
