Question about Kyocera Office Equipment & Supplies
Hello , I have kyocera taskalfa 6550ci with c2810 error code we replace the waste toner motor and PWB, drive shaft is working too but still the problem is there . any help please
    Habit-Forming:
  • 28 Answers
Which PWB did you replace? Check the long PWB in the front of the machine. If the waste toner motor plugs into it you may need to replace the board.
Posted on Sep 02, 2017
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Posted on Apr 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
duane_wong
  • 6826 Answers
SOURCE: Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Posted on Jul 19, 2010
Kyocera taskalfa 1800 call service c7900
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Aug 08, 2016 | Kyocera Office Equipment & Supplies
How to fix error c2730 on a taskalfa 2030ci
Code: 2730
Description:
Transfer release motor error
When the transfer release motor is driven, the transfer release sensor does not turn on/off for 1 s.
Causes:
Defective connector cable or poor contact in the connector.
Defective drive transmission system of motor.
Defective transfer release motor.
Defective engine PWB.
Jul 25, 2016 | Kyocera Office Equipment & Supplies
Error 2810 on kyocera ta550ci
waste toner motor error, under cover on right side of machine, will have to be replaced. also motor could of damaged PWB.
Jun 16, 2014 | Kyocera Mita KM-5035 Printer
Kyocera Mita TASKalfa 180 error code j41
Check that the registration switch lever does not jam inside the guide by pushing on it. You may have to modify the grooves that the lever shaft rides in to allow it to swing freely.
Jul 01, 2012 | Kyocera Mita TASKalfa 180 Black Toner...
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
Jan 05, 2011 | Kyocera FS1120D Laser Printer
KYOCERA 1016MFPo ERROR call 7980
Contents: Waste toner reservoir overflow
problem (when the total number of
copies is less than 100 thousand
sheets)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Causes: Defective waste
toner sensor or
engine PWB.
Check procedures/corrective measures: Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Nov 23, 2010 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
What is error code 2200 on Kyrocera fs-4000dn
The drum unit is jammed. The waste toner gear is jammed from waste toner hardening. Best solution replace drum unit other wise you will have to pull up the unit and clean unit thouroughly.
Usually this problem occurs if unit is used over 300,000 prints.
Feb 09, 2010 | Kyocera FS-4000DN Laser Printer
200 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
