Question about Samsung Televison & Video
Samsung tv does nothing just flashes blue - Samsung Televison & Video
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Samsung B2330HD Blue Still light, no picture?
Hay Junior!
You have a power supply problem and unfortunately this repair sould be done by one who knows electronics specially tv electronics..
Jun 19, 2012 | Samsung B2330HD 23 in. LCD TV
Last night my tv shut off. the whit/blue light in the middle bottom of the tv is flashing 8 times then stops and repeats. i have removed it from the surge protector and tried it in a wall outlet. i have...
My tv is on the fritz too.. Its basically doing the same thing. Im guessing it has the same capacitor problems all those others are having. Mines only 3 years old, paying 1500 for a now $700 tv.. Ive yet to find a price to fix it but nothings going to satisfy me. And all the talk sounds like samsung wont do a thing to help. Ready to invest in a good old am radio and boycott the tv industry. Sorry this wont help but I felt like venting.
Jan 27, 2011 | Samsung LN40A550 LCD TV
Samsung DTB-H260f. Does this unit suffer from the
Yes it probably has a bad cap in the power supply. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7804
Jan 24, 2010 | Samsung DTB-H260F
My samsun lcd vont turn on
Sounds like the powerboard to your tv went out. It can be replaced/repaired. Call your manufacturer for technical support.
Aug 04, 2009 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Samsung le32n had it for 16 months came down this morning blue light flashing on bottom of tv but no picture or sound. Tried swapping cables, sockets, leaving it off for a while nothing helps
Those Samsungs and most other HD units can fail within 6-18 months of purchase.. I would contact Samsung and go up the corporate ladder for help. Otherwise you may be looking at a repair bill that is as high as the cost of new unit.
Craig www.classtorations.com
Jun 08, 2008 | Samsung Televison & Video
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Open Questions:
Televison & Video Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
