Question about Refrigerators
Trcb model 52 temp jumping from 26-38. freezing our kitchens eggs
Can you freeze fresh hens eggs in their shells
Hello Coral,
According to the USDA "Shell eggs should not be frozen. If an egg accidentally freezes and the shell cracked during freezing, discard the egg. Keep any uncracked eggs frozen until needed; then thaw in the refrigerator. These can be hard cooked successfully but other uses may be limited. That's because freezing causes the yolk to become thick and syrupy so it will not flow like an unfrozen yolk or blend very well with the egg white or other ingredients."
Here are more tips:
Can You Use Frozen Chicken Eggs
Feb 11, 2018 | Refrigerators
Can you freeze cooked peeled boiled eggs?
Hi Keith, apparently its not recommended as the white becomes tough and watery. But I accidentally froze some a while back when I stored them in the fridge (they got pushed right against the back wall overnight!) after defrosting they didn't quite taste like eggs anymore! so rather than waste them I just used them for curried eggs and they were fine in a sandwich!
Trust this helps
Regards Alan
May 26, 2015 | Chef Cooking White Choice Gourmet Egg...
Calibrate temp
You need to balance the temp settings. The freezer controls everything and it you have the refrigerator set wrong then the freezer tries to compensate. This means that things get too cold
Apr 03, 2014 | Whirlpool Refrigerators
should be on the interior back wall on the right. you have to pull the drawers completely out to get to it. should be a black knob marked 1 - 9. Set it on 3 to 5 and you should be fine.
Oct 15, 2013 | True Refrigerated Chef Base 4 Drawers
My unit is freezing in the cooling chamber , i think it might be the air handler fan, can i find a diagram of the unit on the internet?
actually i couldnt find it but theres a diffrent on google thats exactly like it so its confussing
Dec 12, 2011 | True TRCB-82-84
At work one of our units gets too cold in the fridge and the tenant says it freezes her eggs.Do I need a new t stat?
if the eggs are placed directly where the cold air from the freezer enters the refirigerator section, they would freeze. The temp of air coming into the ref. sect. is about 12 degrees, by the time it fills the ref. section it is around 38 degrees. try moving the eggs to a middle shelf (just not on the top shelf), If that doesn't work then I would replace the thermostat.
Mar 05, 2011 | Whirlpool ET1MHKXM Top Freezer...
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Fridge temp is set on 1 and milk and eggs are still freezing.
This is a common problem and it has to do with the electronic temperature sensor. Check with Sears to see if there is either a recall or a TSB (Technical Service Bulletin) for your model. They may try to get you to buy a new circuit board, but the solution is actually the temp sensor itself. ( will give you the scematic as well as the part number. Just enter your model and press enter.
Mar 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezing eggs in fridge area and freezing produce in crisper
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Items in fridge freezing..........
set too cold - set temp knob to a lower number
Sep 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
