Question about The Office Equipment & Supplies
When printing a label it will print correctly but feeds out 1/2 another label instead of stopping at the perforation
  • The Master
  • 5,462 Answers
Since you do not say what label printer there is no one who can answer that question.
Posted on Aug 10, 2017
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
  • 40 Answers
SOURCE: Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Posted on Jan 09, 2008
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
jigeo
  • 57 Answers
SOURCE: label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Posted on May 30, 2008
  • 97 Answers
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
Posted on May 06, 2010
How can i adjust the label feed
Firstly the length of the label must be correctly set.
- When activation forward wait on parameter, you can adjust the feed value.
- else you can adjust the feed value in the driver.
Feb 07, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
I'm using my LP-2844 in conjunction with Label Matrix software and I've run into a snag with my printer. When switching between jobs, I went from one label size to another (something i've done...
The problem with this type of printer is that you need to callibrate the size of the label in fact the Length. If you change the length then the printer may stop printing correctly ans stalls.
From your driver try to do a calibration of sensors with your labels and this sould work with this model.
Other manufacturers handle the varying length dynamically.
Jul 13, 2011 | Zebra LP 2844 Thermal Printer
I print a label and when it ejects, it ejects 1/2 of the next label. It doesn't stop at the perforation. What do I do?
hi
check your software (the file that you print)
its may be you have a blank space in your file
otherwise turn to your printer adjustment
Oct 14, 2010 | Seiko Instruments Smart Label Printer 420...
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
How can I fix this problem?
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Aug 05, 2008 | Dymo LabelWriter 400 Thermal Printer
Not printing the correct text / picture
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Label not advancing to tear-off perforation
the feed button.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
32 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
