Question about Video Game Consoles & Games
Why my game is not working I tried cleaning my game but I sill does not work
  • TheHumanToolbox
    TheHumanToolbox Aug 10, 2017
    Hi Amir kacem, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Vcr remote control not working.
Hi! Bella , more research needed .... do you match each remote to its own VCR model?...did they ever work ?...have you put batteries in wrong polarity ?...are the VCR's at fault or blinded by ambient light ?.....are you pointing remotes correctly ?.....try your remotes on dealer's VCR's @ his shop & get dealer to try his remotes on your VCR's , or find a friend with same gear & do the tests there.......that should identify the problem[s] .... take careful notes of the results... & go from there.......jimbanjo
Jan 11, 2015 | JVC Televison & Video
Mouse rotates all over page. won't stay sill
Gay:
I gather that this is an optical mouse... Take a can of dustoff (canned air) and blow into the hole where the light shines out at the bottom of the mouse. Make sure you hold the can of dustoff straight up and down and don't let the liquid spray into the mouse. Change or clean the mouse pad (sometimes that works). You might try to reload the mouse driver as a last resort.
Aug 17, 2013 | Computers & Internet
Ps3 loads the game play it for 2min then will frz then will give disc err and will not play any games tryed a few games and it sill does not work also resat setings to oem
The laser is shot. It needs a new laser. That will fix it good as new. I have changed many of these. If you are technically inclined you can search this on YouTube, there are many videos showing you exactly how to do this. You can buy a replacement laser on eBay for around $52.
May 24, 2010 | Sony Playstation 3 (PS3) Console
Our ps3 quit recognizing dvd's It sill plays games and bluerays
Try setting your resolution to 480i/p and see if you can play one then.
I've also heard of turning off dvd upscaling, although your ps3 should be able to upscale your dvds.
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
My Playstation 2 memory card stoped working.
PEANUT BUTTER AND CHEESE WORKS GREAT JUST PUT A LITTLE ON THE CD AND IT WILL BE FINE
Nov 14, 2009 | Sony PlayStation 2 (PS2) Console
Replaced battery in remote control but it sill doesn't work. Any suggestions
you may have gunk built up in the remote if it is old. i pulled my remote apart, and cleaned under the rubber number pad. i used alcohol to clean the contacts on the pad and on the circuit board. it worked after that. the only other thing i can think of is that one of your batteries is not making contact.
Jun 29, 2009 | Philips DCD778 8.5 in. Portable TV
Problems after replacing toner
You should just have to press the "GO" button to tell the printer that cleaning is complete and the printer will then carry on working once the toner has been added.
Feb 19, 2009 | Kyocera FS-C5015N Laser Printer
Pink screen?
I'm guessing that it's a texture error in the 3d graphics, I'd try deleting any game saving files, but I'm not sure if that will work, so do it at your own risk. It might just be the game, in that case you will have to contact the people who made it.
Mar 15, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
