Question about Dell Latitude D520 Notebook
Dell D520 wont power up
My Dell 520 laptop doesnot power up at all. i checked after removing battery & also with a spare AC adapter but no luck.
  • 952 Answers
Thanks for using FixYa!
I've worked with Dell tech support for a year and whenever we get this kind of problem ( No power when AC adapter is connected ) the culprit is usually loose power terminal or bad battery. If you have a spare battery and it still doesn't charge or turn ON with that. Then you've already isolated the problem. You have a loose power terminal. If your laptop is still under warranty, you'd better contact dell right away. They will give you free troubleshooting and service for that problem. If your laptop is out of warranty. You might want to just bring it to a local shop and have the power terminals re-soldered.
Have a nice day.
- HotRatchet
Posted on Jul 27, 2009
I have dell d520 laptop the problems is when power on laptop thrr lights on after few sec power off. but charing light show that it was charging. wh happend feedback me
Hi sk rashid ko
Have you tried to remove the battery from the laptop and then re-insert it back(without the AC adapter connected to the laptop) to check if this will solve the problem? if not them give me a feedback.
Regards,
Aug 15, 2011 | Dell Latitude D520 Notebook
Lattitude d520 I buy a new ac adapter, and the battery dont charge. I put the battery in other lattitud and it charge. I think my Lattitud d520 is not charging. What may be the problem?
If the battery and AC adapter work fine on a different D520 then you have an issue with the charging circuit on the motherboard. Could also be the DC adapter jack soldered to the motherboard.
Aug 08, 2011 | Dell Latitude D520 Battery PC Notebook
I have a Dell D520 and it currently says plugged in not charging 0% available. I bought a new battery thinking that this was the problem about a week ago. However it again says the same thing. As long as I...
It would that you have a low powered AC adapter. The wattage output of the adapter will cause the problem you are having. Try shutting the laptop down, not suspend, and letting it charge over night. This should charge the battery. I have found that an underpowered adapter will not power both the laptop and charge the battery. You may want to check in the battery compartment for the adapter part number and see if you are using the correct one for your laptop. Please let me know how it goes.
Apr 06, 2011 | Dell Latitude D520 Notebook
My Dell D520 is not charging, but instead running on AC power... Right now it has 3% battery left, but it is not charging, instead it is working on AC power, like it does when it has 100% power... Please...
Make sure that you are using the correct AC Adapter. Dell usually supplies two different ones. They look very much the same. The difference is the amps. One is meant to be used in their port replicator. Look in the BIOS and make sure you have the setting correct for charging the unit.
Apr 26, 2010 | Dell Latitude D520 Battery PC Notebook
Dell 2650 wont charge
run system diagnosis with dell cd. it will start when u boot ur dell 2650 with driver & diagnosis cd
Apr 01, 2010 | Computers & Internet
Has power but wont boot up at all inspiron b130 notebook, was working fine 4 days ago ,
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 15, 2009 | Dell Inspiron B130 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
My dell latitude d610 is stuck on the same part. will go pass
Try removing the AC cord and the battery once system has powered off leave the battery out and the AC cord disconnected push and hold the power button down for 2 minutes reconnect the AC cord and battery and power back up. Please rate if this solves your problem...
Jun 21, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell Latitude D520 Notebook Logo
439 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
