Question about Vacuums
How to clean the brushes - Vacuums
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
You can use a hair comb. You can also use a comb to clean your hair brushes. :)
Posted on Aug 11, 2017
How do I clean the brush area after using my Pro Heat?
The brush or brushes (depending on your model) can be removed if needed. Routine cleaning should just require removing hair and debris from the brushes and wiping the area around the brushes.
There should actually be very little hair or debris around the brush roll if the carpets are thoroughly vacuumed by a properly working vacuum cleaner before being cleaned.
Jan 22, 2017 | Vacuums
It says to clean brushes and they are clean and it keeps making a clicking sound. Only 4 months old.
You need to remove the brush tray and clean all the parts behind the brush housing.
May 21, 2010 | iRobot Roomba 530 Robotic Vacuum
My roomba keeps telling me "error and to clean the brushes. I have cleaned the brushes and when I turn the roomba back on it keeps clicking underneath the roomba. I'm not sure what else to do.
I had the identical problem. I cleaned the brush but the problem persisted. I then put in a new brush that was provided in the box and the problem vanished. I have since used the cleaning tool on the old brush and will try and reinstall it to see if my cleaning worked. In any case a new brush will do the job.
Tim B
Apr 16, 2010 | iRobot 4150 Roomba Vacuum
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
"Please clean Roombas brushes"
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Dec 20, 2008 | Roomba Robotic Floor Bagless Vacuum
Please clean Roomba s brushes warning will not stop after brushes have been cleaned Unit shuts off after one minute of cleaning
Clean the yellow brush bearings. Then run the Roomba without the dustbin, so that you can watch the brush while the unit is cleaning. Is it turning? If not, call customer support. 877-855-8593. Have your Roomba with you; they will want information from it. Good luck.
Dec 13, 2008 | iRobot Roomba 570 Robotic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
