Question about JVC Audio Players & Recorders
JVC XV-F80 a CD feel under the rack and jammed the drawer. Any way to open the draw and release the CD?
  • JVC Master
  • 3,498 Answers
There should be a tiny hole in the front.. use a paper clip unfolded and push..it should open...if not.. then something is blocking it...
Posted on Aug 11, 2017
SOURCE: my pioneer XV HTD1 home
Had this problem yesterday.......was getting v. frustrated. My good lady suggested removing the cover, so I did, when she wasn't looking. Turns out that two DVDs had come off the changer and were jamming the drawer. One was Stuart Little III which my girls had been looking for for months. Took the opportunity to bin that 'course, then told the wife that I'd managed to fix the player "Needed the reverse polarity torque resetting pet".
"So in other words I was right, a DVD was jamming it?" she said smugly.
Posted on Sep 08, 2008
killer_clown
  • 86 Answers
SOURCE: cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Posted on Oct 24, 2008
SOURCE: Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: my jvc model xv-tha35 eject
try resoldering or replacing ic804
Posted on Sep 21, 2010
  • 6771 Answers
SOURCE: my jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Posted on Mar 28, 2012
Tip
CD/DVD drive drawer fails to open ?
I've often seen this problem on Fixya, there's a quite well known solution.
The CD/DVD drive drawer on your PC (laptop or desktop) won't open when you press the button.
Look closely at the front of the drive, usually, just below the draw itself but still on the front bezel of the drive, you should be able to spot a small hole.
This is the manufacturers fail safe release mechanism, all you need to do is straighten out a paper clip, or use something similar, a push it into the hole, quite firmly. This should release the draw and it will pop out part way.
Invariably after doing this, the drive draw starts to function again normally.
on Jun 03, 2010 | Computers & Internet
I can't open the drawer of casio TE4500 F
I dont no the model but sum casio have release under the draw base at the back if not then it as a lock on the front of the draw you will need
that.
Jan 19, 2013 | Computers & Internet
Xv-f80 repair
either a jammed mechanism or a power supply issue in the unit.
If its a multi-disc unit the mechanism is most likely.
May 29, 2012 | JVC XV-F80 Multi-disc DVD Player
My jvc compact component system cd drawer won't open
Mar 27, 2012 | JVC Audio Players & Recorders
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
CD drawer will not open
Most CD's have a small hole in the front of the drawer cover. This hole can be used to open the drawer, straighten out a large paper clip (wire style). About 2" should be enough! Put he paper clip end thru the hole perpendicular to the front (straight in). You will feel resistance at about 1/2" to 1", pressing firmly (don't jam it in), the drawer will start to open as you press the right place, gently pull the drawer open. If something is jammed inside, removal and possible replacement may be required. If you don't feel confident in opening the case, don't!
Oct 20, 2008 | Compaq Presario X1000 Notebook
Jvc th m3030
Hello, if your dvd player is still under guarentee then dont do what I am going to explain, this is simple to get the dvd out undo all of the screws on the sides take the lid off and you should be able to get to the dvd, it should'nt damage the dvd if you push the drawer out to release the dvd.
Feb 15, 2008 | JVC XV-N422S DVD Player
JVC XV-511 Audio OK with CD but none with DVD
Walks' solution worked for me! Thanks lots! I was about to head to the repair store!
Nov 29, 2007 | JVC XV-511 DVD Player
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
