Question about The Audio Players & Recorders
How do I reset the correct time its 16 minutes to fast (CST)
Am....guys i want to know if my watch going 2 minutes back it will be forward after 28 minutes???and how can i fix it?? **its 2 minutes back 4 hours now.my watch is a jaga wr100m orange
You aren't making a lot of sense with this post either. This is a normal quartz watch. It isn't connected to a time server, so you need to correct it.
In the image, the watch says it is 9:41. If the correct time is actually 9:43, you advance it 2 minutes. You say 'back', but the better terms for a watch or clock are 'slow', or 'fast'. Your watch is 2 minutes slow, or two minutes fast? If the correct time is back, (the watch is fast) you need to advance 28 minutes.
Post here as a COMMENT, DON'T start a new post!
Feb 08, 2017 | Watches
Clock display is 15 minutes too fast. How do I correct?
reset the time with the buttons .time and minutes
Jan 26, 2016 | Audio Players & Recorders
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
Why is the time on my weather station always 3 hours behind
You need to set up the correct time zone offset. For example, CST is -6; EST is -5. If daylight savings is active, time will be: CDT = -5; EDT = -4.
CST = Central Standard Time
EST = Eastern Standard Time
CDT = Central Daylight Time
and so on.
The Official NIST US Time
Aug 27, 2014 | Oregon Scientific WeatherStation...
How to set
Hello
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Sep 11, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Clock runs 5 minutes fast
Do you mean you set the correct time initially and then gradually got faster?There may be a reset button on it somewhere,no guarantee.It will probably be a small circle that doesn't look like anything.If there is,press it with a sharp pencil or something just as small.If not,it's just the nature of the beast.I have a radio which slows down over time...and it's a BOSE wave radio and have to adjust periodically!That's about all you can do is deal with it.Sorry if you can't fix it. Good luck!
Jul 25, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
peppermyers@yahoo.com
Apr 02, 2009 | La Crosse Radio Controlled Atomic Clock
Philips phones
Moved from Texas (CST) to Florida (EST). Brought my vonage equip. with me and kept my TX phone number. Just bought a new Philips CD440 phone. I set the date and clock to correct time. When I receive a call, my phone then reverts back to CST (loses an hour). I have checked all my Vonage settings; they show me as having EST and my new FL address. I can't figure out what is making the Philips phone think it is in CST. This is spooky.
Sep 03, 2008 | Lands Phones
Firewire hd not showing up in profiler or diskutility on imac gr
Hello! You know how to take off the HDD from its casing?  okay, No. 1 error is due to loose of connections. All you have to do is to dismantle it. And be sure to memorized where its original position. You need to set the jumper settings of your HDD to master.  next, be sure all the connections are intact and well connected, then assemble it again. next, be sure you are using Power Mac g4 CPU 1.2Ghz with at least 1GB of memory or Higher than G4 units, cause 300GB couldn't be detected lower than that, then plug it in. if it still didn't work out, try to ask help from service center near you to assist you.
Jun 30, 2008 | Fantom Drives 300 GB Hard Drive
27 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
