New unit powers up no sound except rythmic clicking in right front speeker
2 Suggested Answers
ramon49
  • 111 Answers
SOURCE: Brand new Samsung A550 52 LCD Unit has power, no picture or sound
usually a pcb came loose during transit or you have a bad power unit requiring professional repair..
Posted on Mar 08, 2009
Rythmic humming
cv axles going bad?wheel bearing? but you said clicking so i would say cv axles, if its manual check trans fluid, humming can also be the alternator increasing sound with speed overinflated tires etc be a little more descriptive click click? tock tock? clack clack?left side? right side? only when turning? is the licking and the hummming together or seperate
Nov 25, 2013 | 2005 Mitsubishi Pajero 3.2
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
1998 jaguar battery drains, goes dead & a steady clicking begins
Post it in the auto section. A rythmic clicking may be the starter relay firing when it should not.
Jul 01, 2010 | Medical Specialties Pad Training Battery...
Witch wire is goes to what speeker on a sony xplod cd player?
white are left front, gray are right front, green are left rear, purple are right rear. solid color wires are pos.. and with black stripe are neg.
Mar 12, 2010 | Sony XPLOD CDX-GT200 CD Player
I dont have any sound coming out from my speekers but the speekers work because we tryed them on another computer. what do i do? rebecca
Have you checked with headphones in the same port? Is it possible you've selected "Mute"? Check the System Tray near the clock in the lower right hand corner of your screen and make sure there's not a red circle next to the little speaker icon.
Nov 09, 2009 | Microsoft Windows XP Professional for PC
Speekers no sound
Sounds to me like the amp needs power. Is it usb powered? or have a wall plug?
Oct 28, 2009 | Boston Acoustics BA735 Computer Speakers
I HAVE ONLY ONE SPEEKER WORKING, THE LEFT ONE DOES NOT WORK, I KNOW THE SPEEKER IS GOOD. PLEASE HELP
It sounds like there is a blown left channel. Its probably time for a new stereo. But make sure the balance isn't turned all the way to the right first.
Aug 19, 2009 | Car Audio & Video
Ned to wire speekers to my xr 2300 radio
As long as it is a newer model sony the speaker colors are: left front: white. left rear: green. right front: gray. right rear: purple. The black stripes are your negatives, solids, positive.
Aug 17, 2009 | Car Audio & Video
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Computers & Internet Logo
David Payne
David Payne
