Question about Life Fitness Exercise & Fitness
Life fitness 90t. I turn it on, at this point everything appears normal, I press quick start, hear a click and dashes (----) run across the display screen and the treadmill will not operate.
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
  • 4 Answers
SOURCE: Start Error Message when turn the key. No clicking, Dash normal.
seems like your key is not being recognized, possible your tumbler..the ring around your ignition switch is bad
Posted on Sep 21, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 36 Answers
SOURCE: I click on normal cycle and press start and then it doesnt turn o
Could be one of about 7 different things. Watch this Whirlpool video for instruction. http://www.mediafire.com/?42mhcghit1y
Posted on Mar 03, 2010
bwinton
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Posted on May 07, 2010
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
Tip
Buick service light 1991-01
LeSabre,
Park Avenue
2000-01
Turn the ignition to ON. Press the GAUGE INFO button on the driver information center (DIC) switch to view OIL LIFE INDEX. Press and hold the RESET button on the DIC until the display reads OIL LIFE INDEX 100% NORMAL. The engine oil life monitor is now reset. Turn the ignition OFF.
Park Avenue
1997-99
When "OIL LIFE INDEX CHANGE OIL" appears in the Driver Information Center, press and hold the "RESET" button while the oil life index is being displayed. After 5 seconds, the oil life will change to 100%
Le Sabre,
Park Avenue
1995-99
1995-96
When "CHANGE OIL SOON" light is illuminated, access the reset button in the glove box. With the engine off and the ignition switch in the run position, press and hold the button for at least 5 seconds. The light will flash four times and then go out.
Century,
Regal,
Roadmaster
1997-01,
1996-01,
1995-96.
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Fully depress and release the accelerator pedal three times within 5 seconds. The light will flash twice and go out.
Roadmaster
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Le Sabre,
Park Avenue
1992-94,
1991-94
When "CHANGE OIL SOON" light is illuminated, find the hole in the underside of the dash on the passenger side near the door. Insert a blunt instrument into the hole and press the switch. The light will flash four times when the system is reset.
on Dec 07, 2009 | Buick LeSabre Cars & Trucks
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Life fitness 90t error 1
If you wish to get some details treadmill error codes; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 13, 2013 | Life Fitness 90t Treadmill
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    2005 chevy impala: How do I shut off "low tire pressure" warning light?
    Turn your car ignition on but dont start it. Then pull your lights out one click push back in repeat process two more times and you should hear a chime and it will reset. I've had to do this lol
    Aug 15, 2010 | 2005 Chevrolet Impala
    Service engine soon light on in 2004 buick rendevous after accident. no codes given. turns on when engine starts.ran scanner- no codes... had to reset everything after car repairs. told not related to...
    oh thats the change oil light expect it every 3500 to 4500 miles they glow.. you can usually reset it by holding down the trip button with the car off and then turn the key to the II position where everything lights up
    so read me >>>>>
    Buick Rainier 2004-06, Buick Rendezvous 2002-05 w/o (DIC) Driver Information Center
    Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
    Buick Rainier 2004-05 wI (DIC) Driver Information Center
    The DIC display is located on the instrument panel cluster above the steering wheel. The DIG buttons are located on the steering wheel. Press button with the gas pump symbol to display engine oil life. Press button with the arrow symbol to reset engine oil life display.
    Buick Rendezvous 2002-06 wI (DIC) Driver Information Center
    To reset Service Reminder Indicator, turn ignition on with engine not running. Press the MODE button until DIC reads oil life left hold SET to reset. Press and hold the SET button until 100% is displayed. You will hear three chimes and the change oil message will go out. If the CHANGE ENGINE OIL’ message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
    May 08, 2009 | 2004 Buick Rendezvous
    Exercise & Fitness Logo
    59 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
