Question about Frigidaire Microwave Ovens
Frigidaire microwave door closes, but not properly all the time. 50% of the time the light stays on or there is some noise sometimes. We have to knock on the door handle for it to close properly and make the microwave work
  • 4102 Answers
SOURCE: frigidaire microwave won t turn off
this is a problem with your programme timer these can be expensive to replace and because of the age you will probably be better buying a complete new unit as you could repair it and you could come across other related problems and could end up spending a fortune sorry i couldnt be any more help
Posted on Nov 08, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Door Switch Problem?
That model number has too many digits after the JVM. Could it be JVM1339BW02 or JVM1339BW002?
If one is bad, it's probably the bottom switch, whose wiring goes back to the power relay, thermostat, or fuse, depending on eact model.
The switch with thin wires going to a ltitle connector on the board is the door sense switch. That's not likely your culprit.
I usually recommend you replace them all while you're at it.
It sounds like it may actually be a loose or misaligned door or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
GE models have a very helpful "mini-manual" hidden inside the unit behind the control panel. Handy in troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 18, 2008
SOURCE: Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
Posted on Aug 19, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: frigidaire microwave plmv168cc1 makes humming noise when door closed
Chances are that the secondary (cook) relay on the control circuit board is shorted, meaning that the oven is actually cooking any time the door is closed.
You can test that by putting in a cup of water, shutting the door, and letting it go for about 30 seconds, then checking the water temperature.
This is dangerous, and can lead to a fire, so please unplug the oven until it is repaired.
The relay can be replaced for far less than the cost of a new control circuit board.
Posted on May 31, 2012
My microwave door wont stay close , how do i fix ?
Hey Abraham Acevedo, thank you for the post!
From my understanding the door on your Frigidaire microwave, PLMV168, is not staying closed. You could be seeing an issue with either your door latch or latch assembly within the microwave. Since these components require patience and precision to replace or remove from your appliance, I always suggest seeking professional assistance. One must be very careful handling these replacement parts as they can lead to potential harm. -Matt
Jul 30, 2014 | Frigidaire PLMV168 Microwave Oven
Frigidaire gallery microwave light stays on and internal fan stays on
Good Afternoon Friend, thank you for your post!
I see that the internal light and fan continues to run on your Electrolux microwave with the door close. This sounds like the issue is related to a faulty door switch. I am fairly confident that an authorized service agent will be able to restore your microwave to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Hope this helps! - Z
May 20, 2014 | Microwave Ovens
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Frigidaire microwave plmv168cc1 makes humming noise when door closed
May 31, 2012 | Frigidaire Microwave Microwave Oven
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
Oct 04, 2011 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Jenn-Air abovestove microwave door issue
There should be two metal curved hinges the door rides on. When these get out of alignment, you can loosen the screws/bolts on them and adjust the door, then tighten them again. Have someone hold the door in the desired position while you tighten them.
Also, it is possible, if the doors is shutting smoothly, that you have a faulty light switch that could have food/junk on it, and either not push in or make contact properly. Some of the older styles had a ring screw around the base so that you could remove and replace the switch. You can also adjust the switch with that too, by bringing it out a bit more then tightening the ring screw.
Sirwriter
Sirwriter
May 23, 2009 | Microwave Ovens
Door does not stay fully closed
This could be due to a faulty door interlock but in most microwave ovens I have seen the light remains on during the cooking process.
May 18, 2017 | Microwave Ovens
Microwave oven, ge profile model #pvm1870 the light stays on when the door is closed. microwave makes a noise while the light stays on. slight pressure to the door turns the light off.
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
