Question about HOW Video Game Consoles & Games
How do I plant explosives on bridge for Xbox one
Why every time i look for garden bridge for new ideas, i get something about a bridge in London?
There is a new project that has just been designed and is waiting to be approved, for a new bridge crossing the Thames in London. This bridge will be called Garden Bridge as the project involves several trees and plants. The bridge will be only for pedestrians and it will be like crossing a garden.
Here are some pictures of the project
Jan 08, 2014 | Garden
Whats The Order Number For plants v. zombies???
hello. good day sir. this link might help you find a order number generator:
http://www.dl4all.com/x1b/tag/plants+vs+zombies+order+number+generator.html
hope this helps. goodluck!
Jun 13, 2011 | Namco Video Game Consoles & Games
How to setup my xbox to my pc
You will need a network cable (cat5) if you have wirless you will have network card at the back of the pc spare, if you dont you will need a network expansion card, plug the cable into the xbox network socket, it looks a bit like a phone socket, and plug the other end into the pc.
The best windows for doing this is windows vista if you are using wirless internet because it allows you to bridge a wireless and cable connection together, windows xp will not allow this.
Goto network connections, goto start and bring up the menu and click settings, then click network connections, you should have two or more connections, 1 wireless and 1 wired, which will be your xbox, you will need to bridge connections, to do the you will have to highlight the both connections by holding CTRL and left clicking on 1 and then the other, now right click on the highlighted connections, a drop down menu should appear, with a option to bridge connections, left click that and a bridge icon should appear in the window showing that the 2 connections are now bridged, you will now be able to use the computers internet access to enter xbox live. You may find that you will have a strict NAT set up on your router, to avoid this you will need to forward some ports, if you get this far post back i will try to run you through this process.
hope this helps and good luck.
Aug 14, 2010 | Microsoft Xbox 360 Console
How do I make my dlink dwa-130c wireless adapter work with xbox 360 for xbox live
Bridge the Connections. In other words, plug in the internet cable into the xbox, and the other end into your desktop or laptop. After this is done, select both the wireless and the local connections (go to your network connections) and right click on the "Wireless Network Connection" icon. Hit "Bridge Connections" and it should work. REMEMBER that the Xbox WIFI will turn off if the computer does.
Dec 27, 2009 | Microsoft Wireless Network Adapter Xbox...
Can't get xbox 360 to work with motorola wireless g bridge
i don't know if this will work just put the ip address in 192.168.1.1 good luck
shaun
Mar 21, 2009 | Arris WE800G 802.11g/b (498519-001-00)...
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
Can you help me please??
you need to setup a network bridge between the tower pc and the xbox 360
Select Control Panel/Network Connections and while hovering over Network Connections, right click and choose Open. This will open a panel that should list your network connections.
This image shows all my existing network connections. Yours may not have the same adapters. The two adapters that matter are your wireless adapter and your Ethernet adapter. They will have different names than mine because I have renamed them from their default values. I have highlighted the two adapters in the graphic below.
Step 2 If you have both Ethernet and wireless adapters (and you must in order for this to work), then both of them will be listed in the Network Connections panel. Using the ctrl-click selection method or the drag-area method, select both adapters.
Step 3 Right-click one of the adapters and select the Bridge Connections option.
Step 4 You will see a notification that the bridge is being built. This may take a few moments.
Step 5 Once the bridge is complete, you will see the bridge icon and the network adapters as shown below:
Step 6 The bridge is only partially complete at this point. To complete the configuration, you need to relate the network adapters to the bridge. I’m not exactly sure why this is because you have to select the adapters to create the bridge in the first place. This is my first bridge, so it’s possible there is a better way of doing it. But this process has worked for me. If you know of a more concise way of configuring the bridge, let me know and I’ll update the process.
In any case, select the bridge, right-click and select Properties:
Step 7 In the Properties dialog, put check marks in the network adapters that you want to bridge. Make sure you select the wireless and Ethernet adapters.
Step 8 Now, the bridge is complete. It will take a few moments for your laptop to finish the configuration, get a new DHCP lease and complete the connections.
To verify if your bridge works, connect the XBox 360 to your laptop’s Ethernet port and connect with XBox Live.
Dec 10, 2008 | Microsoft Xbox 360 Console
Metal Gear Solid 2: Sons of Liberty disc error (PS2)
is the disc dirty or scratched
its also possible its somehow faulty are you still able to return it under warrenty
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
37 people viewed this question
Top HOW Video Game Consoles & Games Experts
vince
John Hong
John Hong
Are you a HOW Video Game Console and Game Expert? Answer questions, earn points and help others
