Question about The Computers & Internet
For how long will it take for the local people to understand the one who stand for them to bring a light to the majority of black people(black empowerment in other words)
I want to fit a light and switch into my new workshop. I have a garage type consummer unit fitted and am not sure how to wire in the light.
I answer questions for free.
I know electric wiring.
However I might not understand your problem.
If I do not understand your problem, add a comment with more information and I will respond.
If I understand correctly you want to add a new switch and a new light in your garage.
And you are starting from scratch with no knowledge.
You are starting with a blank wall.
I do not know what a consummer unit is.
Is that a type of light?
Here's a sketch of the project:
We need an electrical receptacle or wall-plug so we can get electricity.
We need to run a cable from the electrical wall-plug to the switch.
This will bring electricity to your switch.
And then we need to run a cable to the light.
Let's talk about how you get electricity from the wall-plug.
The wall plug has a black and white wire connected to each side.
Your cable has a black and white wire.
You connect your black wire with the black side.
Connect white to the white side.
Now run the cable to your switch.
The cable arrives at the switch.
The cable has a black and white wire.
The switch is wired differently than the wall-plug.
On the switch you connect one black wire.
But the white is not connected to switch.
Now we're ready for the cable going to the light.
The cable to the light has a black and white wire.
Connect the black to the switch.
So now you have 2 black wires connected to the switch.
The black wires are on different screws.
And then connect the two white wires together.
So the switch is wired.
Run the cable to your light.
The cable arrives at the light.
The cable still has a black and a white wire.
Your light will have wires -or- it will have screws.
If light has black and white wires, then connect black to black and white to white.
If your switch has screws, then connect black to brass-screw and white to silver-screw.
Oct 30, 2010 | Electrical Supplies
When i turn on the monitor it flashes on once for a few seconds t
faith1114, Try this first! See if any thing seems a little similar to your f1903 type of complaint. Problem been around a long time!!! Go do some reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution. After doing some reading there, you will be in a better position to make decision to DIY repair, contract out the repair work, trade in for new , DIY repair + buy a new monitor keeping refurbished f1903 as emergency spare. Here is a little clue. If unit can display Win-desktop for 2 seconds and then the "black screen of death happens" you certainly need to do some reading and viewing of DIY videos at YOUTUBE so you can understand the big problem all major CCFL back-lit lcd monitor manufacturers are facing. do some additional reading here at fixya in the profiles of ccfl backlit lcd monitor technicians "budmrtn" "buddymc" , "12fixlouie" (late) "louie12fix" (old) Follow links you find there. Once you understand basic problem you will never walk past the new curlie-Q, screw-in energy-efficient CFL light bulbs at the local hardware or big box homecenter ever again with out having a slight grin on your face!! Bye for now. 12fixlouie
Jun 02, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My 65" sony rear projector
shorted green tube sony had major problem with Tubes
May 27, 2010 | Sony KP-65WV600 65" Rear Projection...
Green light comes on but nothing else happens. No
try bringing it into a sony store and asking whats wrong with it
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Power button lights up, can hear fan running - but screen is black. Last time it was locked with BIOS password screen
Ok now if i understand correctly, you have a complete blank screen when the computer is booting up. And it's the same if you connect to a monitor. Well your video output looks alright then, but no signal is sent to it.
This is a video controler problem and I really hope your laptop is still in warranty because replacing the main board (which includes the video chip along with many other stuff) is very costly.
IF, you can see the POST boot up messages, the previous information is irrelevant. But if as you describe it the screen is black at all times, the main board needs to be replaced.
Anyhow I strongly suggest you contact your dealer or Toshiba to know how much it's gonna cost to replace the main board or even bring it to a local store where they can evaluate the problem and repair it.
Jun 03, 2009 | Toshiba Satellite A135-S2266 Notebook
Can't get stand by light to go on television. Therefore tv won't
The set is going into protect. There is a major problem , usually HVoltage. Recommend Pro Repair. Could be loose modules about 5% chance. Protect is preventing major repairs and costs , so get it repaired now. Unplug and be safe..
Apr 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Orange symbol on dash
What does the light resemble?
Sep 30, 2008 | 2003 Saab 9-3
Onkyo TX-SR575 I bought this unit at a flea market. Comes with everything including the manual except for the remote control. Manual is somewhat difficutl to understand. Stand by red light keeps...
The unit is in protect mode. The outputs are fried in all likelyhood. This can be repaired. Figure on $5-$15 for parts plus the local labor rate for the total repair cost.
Dan
May 21, 2008 | Onkyo Audio Players & Recorders
VAIO PCG-XG9 BLACK SCREEN
will i guest your computer have a major trouble...just try to check if the power led is ok the light is blink...or just check also if have 3 beeps sounds with regards to the video card...my suspect is weather a power supply of your computer or a video card is defective...let us bring that to the service center......
Dec 16, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
