Question about Home
Our sani pump 2 is not kicking in when the toilet or shower are used. We have to switch the pump off and on again each time we need it to process the waste. Could this be fixed?
  • 44 Answers
SOURCE: hi, I had my sani plus for a year now , the shower doesnt work
so the wc works but notthe shower, where the shower connects in on the saniplus is a not return valve which could be stuck in the closed position??
Have you checked thatthe shower trap isnt blocked with hair etc.
If the wc works & the unit is pumping away then the motor is working ok, so it could be a flow switch problem or as i said thers no flow through the shower waste pipe-work due to a possible blockage
Posted on Dec 20, 2008
  • 7 Answers
SOURCE: shower does not empty
Did you try to plunger the shower drain?
Posted on Feb 12, 2009
  • 62 Answers
SOURCE: Sani-Plus
float switch of level control is defective. replace same with new part
Posted on Jun 12, 2009
  • 54 Answers
SOURCE: my sani slim system smells when i use the shower
Your main branch drain or stack is plugged. Call rotor rooter
Posted on Sep 26, 2009
jyackle5
  • 8197 Answers
SOURCE: I need fitting instructions for archimedes 4 shower waste pump
May I get the make and model # to help you more
Posted on Apr 05, 2010
Sani flow won't empty so shower toilet n sink all fill up
Most likely is the capacitor/condenser that has gone bad, if there are no blockages in the blade or impeller then the capacitor will need to be replaced. The capacitor is located inside the pressure chamber. Refer to the installation manual to locate it and call Saniflo to order the part.
Feb 27, 2013 | Saniflo & Saniplus& Macerator Pump
When our toilet is flushed there is a lapse of a few seconds before the pump kicks in and during this time some water comes back up the shower drain. It does not seem to be waste from the toilet but we'd...
The plumbing under the slab floor has been roughed in wrong and without breaking up the floor and replaceing you cann adjust the floats in the pump pitr to come on earlier to avoid pit filling up as fast causing the waste to back up in the tub/ shower area.
Oct 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Plus
Soak it in descaler and cold water for 24hrs then try again (may take 3-4 attempts) or remove pump/motor from the tank, find oval black rubber membrane, should be able to hear click of switch underneath when membrane is pressed, new membrane required if it is not flexable.
Feb 14, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My sani slim system smells when i use the shower
Sep 25, 2009 | Home
Shower tray is low and fills before saniflow kicks in cant alter height of tray
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Jul 13, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Jul 05, 2009 | Saniflo & Saniplus& Macerator Pump
Sani-Plus
Jun 05, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanishower operated for short time and then just went to a buzzing noise - first time operation - any suggestions
It needs cleaning out regularly - at least once a year! We have one fitted to a shower that is used daily. The small amount of hair - that falls out every time hair is washed under the shower - builds up and clogs up the pump. We are on our second pump, the first installed just over 10 years ago, this one is under 3 years old and it already looks like it will have to be replaced.
Mar 03, 2009 | Saniflo & Saniplus& Macerator Pump
Hi, I had my sani plus for a year now , the shower doesnt work
Dec 18, 2008 | Saniflo 002/005/007 Saniplus Toilet with...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
