I have an error E-3 on my monitor - Computers & Internet
How do i correct error code 3 on blood pressure monitor
error code 3 is usually air pressure, too much as in a tight cuff (loosen it) or the hose is loose or off altogether.
look at he google search below or do on with your specific BO monitor manufacturer and model etc,
Google
Aug 01, 2016 | Cameras
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
Saturday, April 16 9:55 PMI have a Life Fitness Blood Pressure Monitor and I haven't been able to use it since yesterday evening. I purchased it about 11/2 years ago and needed to get a copy of the...
Error -! Air circuit abnormality. Solution: Measure again
Error -3 Error determining measurement data. Solution: Measure again.
HoMedics is the manufacturer. You can contact their Customer Support Dept 800-466-3342 for an Owners Manual.
Hope this helped you.
Apr 17, 2011 | Health & Beauty
I get error codes on the unit. Can you tell me what the error codes mean?
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:hemant_pandya12@yahoo.com I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
H.M.PANDYA.
Mar 03, 2011 | Lifesource Digital Blood Pressure Monitor...
I think my monitor and/or driver /cable is causing a blue screen error on my dell inspiron laptop???? is there a driver update or something else i can do to update my monitor?
blue screen error is not there because of monitor's driver
there are others reasons like
1. smps supply may be faulty you may swap it with some other
2. recently software is faulty
3. mother board is faulty
Aug 27, 2010 | Sony SDM-HS74P/S 17" LCD Monitor
I have the Prevention wrist monitor WS820 What does the error code -3 mean?
Deflation Error - Movement or talking was detected during measurement.
Turn off the power and make another measurement while being quiet & still.
Aug 06, 2010 | Prevention Wrist Blood Pressure Monitor...
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
What does error 3 on my microlife blood pressure monitor mean?
I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
Jun 28, 2009 | Microlife 3AC1-PC Blood Pressure Monitor
Computers & Internet Logo
David Payne
David Payne
