Question about Refrigerators
Hi, I have a 9 year old TPS24TP. I can get water thru the door, but the ice maker does not make ice. I pulled it our of the enclosure and see that there is water in the lines going into the water feed, but not to the icemaker. Is there something I should check before calling a service tech?
  • hcedwards Jul 28, 2009
    I found what you are talking about behind a panel on the lower left had side of the refrigerator.
    I removed the bracket and have a solenoid valve where the water enters. This is connected to two more solenoid valves. One appears to control a single line to the ice maker, the other controls two lines that enter the refrigerator. I assume the second is for the chilled water.
    How do I get the plastic lines/tubes out of the solenoids? I removed the plastic collars, but the tubes do not want to pull out. Should I just give them a hard pull?
    I spoke to the local appliance repair company, one I have used before. They stock a kit will all three valves for $64.95. The single valve for the icemaker is $32.59. I am going to pick up the three valve kit this afternoon and swap them out.
    Thanks for your help.
  • 631 Answers
Well there is a water valve on a lot of the fridges and that water valve has water doing to the dispenser and there is a water line from the valve to the ice maker. These two lines are separate and the ice maker valve can be bad. They are generally down towards the bottom of the fridge and can be replaced. You just have to trace down the water lines and see where they go. Here is a shortcut that may possibly have the drawings for your fridge and parts if you need them. http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
  • outdoorsman5
    outdoorsman5 Jul 28, 2009
    The thing to do is cut the line somewhere above the valve but make sure your water valve is off otherwise it could be a wet situation. You will need a ferrel and brass connector to connect the line back up if the valve is good but you can cut it then turn the water back on a little to see if water is coming out of the valve. It the water is coming out of the valve to the ice maker then there is something else wrong. If there is no water coming out then change the valve. I believe they make a special took to undo the connector but not sure. If you pull it out you will never get the hose back in. I been that route before. Make sure you have someone else there to watch if there is water coming out otherwise you will have water all over. There is a possibility the line could be froze up somewhere where it enters the ice maker that is why you are going to check the valve first. I would bet it is the valve. Let me know what you come up with.
No ice, it has water on door but no ice.
There are two sides to a water control valve. The ice maker side and the water dispenser side. So what I am saying is the problem could be the ice maker side of the dual water control valve. Is there still old ice in the ice maker? If not then pour tap water into ice maker. If after the water freezes and then dumps the ice into the ice bin that will indicate a defective water control valve, If ice maker does nothing but hold old shrinking ice cubes this would mean you have a defective ice maker. Let me know your model number and I will look up the part numbers. I will be here should you have questions, Thanks Sea Breeze
Mar 11, 2013 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
No ice cubes
Ice. refrigerator one year old.maker will not kick ice cues out
Oct 21, 2010 | Whirlpool Centralpark 25.6 Cu. Ft....
We had this ref for almost a year now and it has not made ice in 2 days..Help please!!!
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 30, 2010 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice flap door won't close - Freezer and ice maker frost up
Every time you use the ice dispensor , when the flap opens , cold air will fall inside the enclosed dispensor cover . This cold air , mixed with the warm outside air , produces moisture inside the cover . After so long , this moisture starts turning to rust , causing the solenoid and plunger to rust . G E has no "fix" for this problem yet . My suggestion , would be to drill holes in the bottom of the dispensor enclosure (white plastic enclosure , held on by 4 screws ) at certain points , so that the cold air will fall thru the cover , instead of staying in the enclosure . This is something I have to try on customers refrigerators for a while , before I send this Idea to G E . To answer your question , yes , I is normal to replace every couple of years ,.....for now anyway .
Sep 11, 2009 | GE Refrigerators
Ice making problem
There is a metal wire that gets pushed up when the Ice becomes too full and turns off the ice maker. You can pull it back down with you hand and that will unlock it and turn the ice maker back on.
Sep 25, 2008 | Refrigerators
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Ice maker not working, water not going in tray.
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
