Question about Microsoft Xbox 360 Console
My Xbox 360 makes a loud humming noise while i play
When i start playing a game on my xbox 360 elite the xbox emits a loud, low hum the entire time. I've noticed that it doesn't always do so when i play a brand new game. Also a big problem which may help you find my problem is that i have had to buy three Halo 3's in the past because even though i take great care of them they end up scratched. My xbox has not taken damage of any kind of what i know of but once, early on in my ownership of my xbox 360 elite i had to move my xbox while a disc was playing a weird, metalic "shredding" sound came from my xbox that lasted about 3 seconds. I greatly appreciate your help. Finally you may also want to know that while not extreme (just a little dust) the xbox sits in a dusty environment. Much Thanks Xander
  • 67 Answers
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
Posted on Jul 27, 2009
  • daniel011 Dec 28, 2010
    just puch it and after that puch it more
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
My xbox 360 makes this really loud buzzing sound or humming sound when I play certain games some games are fine they dont make a loud buzzing sound.
Its probably because you have the game in the wrong way. That happened to mine and i realized it was in backwards. So check that out and reply back. Also don't move your Xbox 360 with a game or DVD in it, it will get the game/ DVD scratched up.
Feb 22, 2011 | Microsoft Xbox 360 Console
Xbox 360 is loud - sounds like a loud fan motor. How can I make it run quietly?
You can try installing the game you want to play on the Xbox 360 Hard Disk, which reduces the motor noise to an extent, however there is no permanent way to fix the loud fan motor noise while playing the game with the disk in the drive.
Make sure you keep your Xbox 360 unit well ventilated, ensure it does not gather dust near the small vents and openings on the unit.
Regards
KreativeGeek
Dec 26, 2009 | Microsoft Xbox 360 Console
Xbox makes noise playing discs
I know what you mean , some drives are LOUD .Try wraping it
with towels ,just kiding . I have recived alot of request to quite
these drives down , I am working on a sound insulator
that will wrap around the cd rom to knock 10-20db off
but i have to watch out for heat build up. Ill keep you posted.
Bobby.
I presume the unit works fine it's just loud, right?
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Humming sound
This is the Fans or from the game/dvd being played...
Common my xbox 360 does this also..
May 17, 2009 | Microsoft Xbox 360 Console
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
XBOX 360 Elite - Will Not play games
Try to update the firmware of your xbox.
Jul 28, 2008 | Microsoft Xbox 360 Elite Console
Xbox 360 elite
sound like the alignment with the disk drive is maybe off track and the disk is buzzing. send to xbox for repairs
Jul 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 Disc drive
no that's not good the motor is working over time you need it looked at quick or the moter will give up and then it will be a bigger job more money try thhttp://www.gamevania.com/XBOX_360/repair.phpis site first.
Jan 03, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,188 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
