Question about Air Tools & Compressors
My compressor keeps pumping but air pressure in tank doesn't go up what is the problem
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
I have a compressor and the last time I used it, it was doing something similar. I haven't tried anything on it yet but I think there are two possibilities (Either it needs oil ) (It may need some air pumped into the tank to get it to build up pressure.) Either those two or the pressure switch is bad. The switches usually are very tough so not likely that but as a last resort I would try a new one. I do think lack of pressure would likely be the oil is low. I think the oil makes a seal around the piston and that causes it to build pressure. If it will still blow up a tire there should be enough pressure to turn the relay switch off. Mine will still blow up a tire so not sure if it is a pressure problem. May need pressure put into the valve on the tank and if there is one I will try that today.
Posted on Aug 12, 2017
  • 104 Answers
SOURCE: coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Posted on Oct 26, 2008
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 867 Answers
SOURCE: kobalt air compressor will not go above 80PSI
if this is an older or much used unit, cylinder/piston may be worn, unable to push higher psi, which would explain no leaks. if newer unit, seems like regulator unit/valve faulty
Posted on Jul 24, 2009
SOURCE: Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Posted on Jan 04, 2010
  • 843 Answers
SOURCE: why does my compreeor switch release the air after
There are two valves in play here. There is a relief valve that opens when the motor kicks off to release the pressure in the compressor itself. That is normal, and is required so that the motor can restart next time without having to overcome that pressure. The other valve is the problem. It is a reed valve between the compressor and the tank. This valve's job is to prevent the air in the tank from returning to the compressor. Think of it as a ratchet for the air. It is this reed valve that has failed.
Posted on May 27, 2010
Leaking around Pressure Switch. Ordered & replaced switch but still leaking
Some pressure switches have a valve that reliefs the compressor head pressure when the motor stops and closes the head pressure relief valve when the motor runs.
There is a check valve that keeps air pressure from coming back to the compressor head and the relief valve.
I think the check valve is leaking tank pressure to the relief valve and compressor head.
The check valve is where the pressure switch mounts on to and it mounts threaded on to the compressor tank.
Try replacing the check valve
Nov 01, 2015 | Craftsman 33 gal Air Compressor 6 hp...
Compressor runs fills tank but then it wont keep the pressure, won't restart to keep pressure above requested pressure. I have to let it seat for 1/2 hour to restart again
Most likely problem is the tank fill check valve. The most common way a a tank will loose pressure is by leak-back at the check valve. This also makes it hard to start because it leaves the tank pressure on the pump head instead of letting it bleed off. The motor will only restart after the tank pressure is bleed off to a low level, reducing the back pressure the motor will have to overcome. Leaking can be heard at the pressure switch, where the air is normally bleeds off over 10 seconds or so after the motor turns off. A defective check valve will continuously leak down at the pressure switch unloader valve instead of bleeding out in just 10 seconds. The check valve is an assembly that is largely hidden inside the tank. It just looks like a large hex nut where the filler tube from the pump enters the tank. Removal usually means first removing a smaller hex/barb/connector where the smaller relief line ties into the big nut. Inspection of the check valve will easily reveal whether this is the problem.
Oct 20, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a husky scout 1.5 gallon air compressor. It only builds pressure to about 38 psi. It doesn't build up any more pressure.
You have either warped or broken reed valves on the valve plate or a broken piston ring and/or a damaged cylinder. Any of these will allow a small amount of air compression but as the tank gets pressure in it, it gets harder to push more air into it. If the reed valves or piston to cylinder seal is compromised more and more air will leak past the bad reed or the piston as the pressure goes up in the tank. You'll have to disassemble the air pump to find out what's damaged and needs replacing.
Mar 03, 2012 | Air Tools & Compressors
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I have a vt631401aj campbell hausfeld compressor. when it builds pressure to 135 psi, the compressor shuts down and immediatly starts dumping air until it goes down to 90 psi. It then stops dumping the...
John: I had a similar problem with a brand new CH-made compressor. The problem was not with the unloader valve, but with the check valve located where the air from the pump enters the tank. The check valve was not seating correctly due to brass filings from manufacture. The defective check valve was allowing air to escape back the wrong way from the tank to the pressure switch and through the unloader valve. This backflow from the tank would start to happen when the pump stopped after reaching high pressure. The back flow would continue until the pump restarted at the low pressure point. This cycling would continue as you described. Once I cleaned the check valve, everything (including the unloader valve) started working correctly. I hope this helps. And remember, don't work on these when they are under pressure and always wear safety glasses.
Sep 18, 2011 | Campbell Hausfeld Air Tools & Compressors
I have a model# 919166442 air compressor that all at once quit building air pressure. when it gets to 40psi the engine keeps running but air pressure wont rise
There is a check valve that has gone bad,this allows air into the tank,and does not allow the air to go back toward the compressors head.This can also cause the compressor to lock up.
May 17, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a air compressure with a square d 9013fhg44mix pressure switch. The problem is where the 1/4 air line goes, this valve leaks when ever the compressor is off. Once the compress is on it is off and...
The 1/4" line is very necessary and there are no adjustments on it. When the tank reaches full the pressure switch turns off the power and opens the valve to the 1/4" line to bleed off pressure from the air pump and feed tube so the motor can turn over the next time the tank drops to the kick in pressure. Every time the pressure switch turns the motor off a small amount of air should be heard coming out of the bottom of the switch for three to five seconds and then it should stop completely. If air continues to leak out of the switch by the 1/4" line, you have a bad tank check valve. The tank check valve is the brass fitting at the other end of the 1/4" line where the feed tube from the air pump goes into the tank. It keeps air in the tank after the pressure switch turns off the motor. Easy to replace, find the one you need for your model compressor.
Mar 25, 2011 | Square D 9013FHG14J52M1X Air Compressor...
Will not build up pressure
worn out pump on the compressor, or leak in tank.
Jul 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Feb 02, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
114 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
