Question about Refrigerators
I have a hoover frost free a class fridge freezer that is too cold for tomatoes and and other salad foods. It almost freezes them. Is it the thermostat and if so how simple is it to fix? thanks
  • 77 Answers
Sounds like a bad thermo stat it is not maintaing the proper temps in fridg area....
Posted on Jul 28, 2009
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 26, 2011 | Hoover Refrigerators
Hoover a class, fridge freezer, fridge keeps icing up and is supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | Hoover HCA390FFK Bottom Freezer...
Freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Jul 27, 2010 | Hoover Refrigerators
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Fridge is freezing food
I have had the same issue with thick frost/ice at the back of my Fridge and almost called an engineer and considered replacing it.. BUT you don't want to so that: Do this:
1. Take freezer draws out and empty fridge so it is lighter and easier to move Fridge Freezer out
2. Chuck some warm soapy water down the drainage hole in back of fridge to ensure it is not blocked
3. Pull the plug. Leave it off for 5-10 mins.
4. Plug it in, reload her
5. Next morning.. perfect all back to normal
I think the unplugging just resets the thermostat and gets your machine back to life.
Jan 13, 2010 | Hoover Refrigerators
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
864 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
