Question about Garmin GPS
Garmin 160 fishfinder backlight not working
4 Suggested Answers
SOURCE: Garmin Fishfinder 160 will not display bottom
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
Posted on Apr 07, 2009
cd_droptop
SOURCE: garmin fishfinder 160 blue . no powerup
I have a 160 blue also, and this morning I had the same problem. I called tech support while I was out on the water but no help. When I got home I double checked my connections on the battery minder/selector and the fuse panel. My GPS worked fine but the FF only beeped, like it had low power and the display wouldnt come up. It came up once for about a second and then faded earlier on the water. I pulled the power and ground connections from the fuse block and put them directly on the battery, it came right up. I now run the FF wired straight to the single battery and the GPS and other items on my other battery.
Hope it helps.
1998 19' Proline Center Console
"Lucky in Love"
CD
Posted on May 01, 2009
budgie140
  • 501 Answers
SOURCE: Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Posted on Jul 08, 2010
Wont power up, i replaced the power cable with a new one and still nothing, dose the transducer need to be connected for it to power on ?
The PWR button also adjust the backlight of unit. Press and quickly release to cycle through brightness settings. All else fails call Garmin www.garmin.com/support
Mar 25, 2016 | Garmin Echo 100 Fishfinder
I need to connect a Garmin 160 transducer to a garmin 120 fish finder
If I may inquire, how many pins on the transducer and on the fishfinder.
Hope to hear from you and pls post back the requested information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Garmin GPSMAP 188 Fish Finder/GPS Receiver
My fishfinder is not operating
There is a good support for Garmin at this adress
http://www.garmin.com/us/support/
Nov 19, 2014 | Garmin Fishfinder 400C 4-Inch Waterproof...
Jul 08, 2010 | Garmin Fishfinder 90
Garmin Fishfinder 140 How to reset sonar failure
Garmin Fishfinder 140 How to reset sonar failure?
Jul 06, 2010 | Garmin Fishfinder 140
Can I get an inboard transducer for my Garmon 160C fish finder?
Yes you can. You would need Garmin part #: 010-10224-00. You can order this part off the Garmin website if you do a search for 160 and look under the accessories.
Jun 16, 2010 | Garmin Color Fishfinder 160c
When using it it sometimes go very faint and sometimes completely dissapears, it's not relaiable at all times
Hi.
That is a malfunction with the backlight system. Ensure that the power adapter is well plugged.
Ring Garmin at the number listed on the manual to have the unit repaired or replaced.
Jan 06, 2010 | Garmin Fishfinder 140
Garmin fishfinder 160 blue . no powerup
Hope it helps.
"Lucky in Love"
CD
Mar 19, 2009 | Garmin Fishfinder 160 GPS Receiver
Garmin Fishfinder 160 will not display bottom contours and does not display depth continuously.
Good luck
Willem
Mar 01, 2009 | Garmin Fishfinder 160 GPS Receiver
GPS Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
