Question about Hot Tools Health & Beauty
Hot tools curling brush on button is not lighting up and it is not heating up. Its brand new out of the box. any ideas?
4 Suggested Answers
  • 27 Answers
SOURCE: Brand new HP Laserjet printer
hi the chairman..
when do bought that printer..from my experiance the paper curl couse of fuser got problem...
need to bring to hp centre...
Posted on Nov 07, 2008
  • 447 Answers
SOURCE: brand new machine red button doesn't depress- it feels springy but doesn't click therefore brush not working
if the previous solution does not work, as its new its under guaratee,and its also covered by the sale of goods yake it back to where you bought it because its down to them to sort the problem out. best of luck.
Posted on Nov 14, 2011
  • 2468 Answers
SOURCE: brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Posted on Feb 17, 2012
I have a Instant Heat 1 ½" Curling Iron by conair and it won't curl my hair. I've never use a curling iron this big? Any ideas?
Try putting styling gel or hairspray that is heat resistant in your hair first before curling it. but make sure products are for heat and styling first so it wont burn your hair! I have very fine hair that is straight as an arrow, and very hard to curl so before i use any curlers or curling irons, i put styling gel or mousse in it first then once I brush it out spray it again to hold the style
Mar 29, 2017 | Conair Health & Beauty
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
Paper printing hot and curling on kyocera taskalfa do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
How to work Conair Volume Hot air curling brush
has 2 parts: a) use heatings elements b) blower for supply the hot air
God bless you
Jan 25, 2013 | Conair Volume Series Hot Air Curling Brush...
I have a CP2025 Laserjet and the paper curls upon exit. When I first started using the printer, there was an option for no curl and it has disappeared. The people at our help desk do not know anything...
Hello i m giving some tips to u it may be helpfull to u
1. Press the "Setup" button to access the Setup Menu.
2. Press the down arrow button until "Service" is displayed.
1. Press the "OK" button.
2. Press an arrow button until "Less Paper Curl" is displayed. Press the "OK" button.
3. Press an arrow button to display "ON" and press the "OK" button.
NOTE: When 'less paper curl' = ON, sets the fuser to Light media mode, or uses less heat to reduce the amount of paper curl. The 'default paper type' gets set to 'light 60-74g'. As a result of this setting, the control panel may prompt the user 'load Tray 1 with Lite Letter' when printing.
If 'less paper curl' = OFF, then 'default paper type' gets set to 'plain' again.
if ur problem not resolved after this exercise then give me ur mail id i will send some more tips...good luck
Jul 30, 2010 | HP Office Equipment & Supplies
No hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
Hope this helps.
May 11, 2009 | Water Heaters
Brand new HP Laserjet printer CP 2025 appears to be running a little hot, causing excessive paper curl
hi the chairman..
Nov 07, 2008 | Office Equipment & Supplies
Health & Beauty Logo
29 people viewed this question
Top Hot Tools Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Hot Tools Health and Beauty Expert? Answer questions, earn points and help others
