My t v goes on after being shut off. I've used both the Rica remote and my cable remote however it's shut off it still goes on by it's self, model LED48G45
Remote bypass
I assume you mean ohms in which case that's just about right unless it's a great distance away. Connect the remote directly to the water heater using a short cable to verify if it shows the same code. If the code goes away then you need to run a new cable, there may be something interfering with the cable. If you get the same code you may need a new control board.
Feb 06, 2013 | Rheem Tankless Hot Water Heater...
I've Cannon 1100D and I bought Cannon RC-6 remote controller and I didn't know how to connect it with my 1100D. Can anybody help me ?
Hi! Unfortunately,the remote controler RC-6 isn't compatible to your 1100D. Because this Canon model doesn't come with the options for remote control, but you can use the Rs-60e3 wich is a cable remote.
Hope it helped!
Sep 03, 2011 | Canon RC6 Wireless Remote RC 6
My t,v. jusrt goes to 6 stations and i have cable. instead of it being on cable as usual it says air where it usually says cable. It is a apex t.v. and apex control, thank you joyce.
Which model of APEX TV do you have?
In general, if the TV has had the source changed, you will need to switch it back from Air (OTA) to CATV (cable). Newer TVs may have the choices of Air and Cable for the TV source.
To change the setting, press Menu (on the TV (if present), on the original remote (in TV mode) or on a substitute remote with the Menu function). Use the up/down arrows to select the TV submenu. Select this menu with the right arrow. Then go down through the submenu to the Source line. (It may read CA-TV/Air on an older TV.) Use the left/right arrows to toggle the setting. Then press Menu to save the setting and return to the previous menu. Then go to the CH Scan option in this menu to rescan the available channels.
Note: I've gone through the directions for an older Apex TV (AVL-2076) with an analog (NTSC) tuner. The directions will probably be similar for other TVs but the menus (and sub-menus) may have different names or be in a different order.
I hope this helps.
Aug 04, 2011 | Directed 434MHZ Remote Control
I need remote code to program new remote
1548, 11548
DirecTV: 10030, 11704, 10019, 10497, 10056, 10056
These two codes will work with models:
TFTV1022, TFTV1212, TFTV1513, TFTV1514, TFTV1524, TFTV1913, TFTV1923, TFTV2214, TFTV2224, TFTV2617, TFTV3217, TFTV4217
Keep in mind that these codes are not guaranteed to work, they've worked on a few cable/satellite boxes for Direct TV and Cox.
0057, 0046, 0083 0085 011, 014, 019, 027, 038, 12355
These three codes will work with the models:
TFTV1525, TFTV2225 and TFTV3225 (VZON TFTV1500, TFTV2200, TFTV3200)
These three codes are not provider specific, however, they've been confirmed to work for a few customers that have Comcast cable service. These codes can be tried with any universal remote control for the above models.
Comcast: 12017 (User submitted), 11531, 11265 (confirmed to work with TFTV2425)
Jun 24, 2011 | Coby 40 TFTV4028 LCD TV
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Tv just goes blank shoots off then i have to turn it back o n
Using the menu/options button, check whether there is a sleep timer. You may have accidentally set it, and it will shut off the tv at either a particular time, or after a period of time has elapsed.
Jun 30, 2009 | RCA Universal Remote Control
How do you use a remote shutter release for a canon d 50 slr , and where do you find the timer on same camera?
You need a remote shutter release button attached either via a cable, or wirelessly. Canon make several models, as do many third parties.
As for self timer, press the AF-Drive Button then use the select wheel to move from single shot to high speed, slow speed or self-timer modes.
Feb 19, 2009 | Canon Cameras
My remote for my sv2000 dvd recorder model#wv10d6 won't work
If your absolutly sure the remote doesnt work there is a power button on the unit its self. As far as a universal remote goes, I my self would like to know that. After much research I have found no info on another remote working
Nov 21, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Televison & Video Logo
Top Televison & Video Experts
