Replacing quick connect on dpac 8399 - Heating & Cooling
5 Suggested Answers
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
  • 4736 Answers
SOURCE: HI, When using the Danby model DPAC 8399 as a
Yes, you certainly do. The unit has to exhaust either as a AC unit or a Dehumidifier.
Posted on May 29, 2011
  • 910 Answers
SOURCE: manuals for danby dpac
Do this manual give you enough information for what you need?
http://dl.owneriq.net/6/6552f631-09a9-4b86-8e47-34c59010e2b1.pdf
Posted on Jul 21, 2011
  • 4736 Answers
SOURCE: have a portable air conditioner
Slide the rear cover of the remote in the directions of the way the arrows are pointing.Continue pulling gently until the cover separates completely from the unit. Insert 2 - AAA Batteries in the direction indicated inside the holder. Reinstall the cover and you're ready to go.
I hope this helped you, Nando. Thanks for choosing FixYa.
Posted on Jul 25, 2011
Have a portable air conditioner Danby model DPAC 8399-3. Could you tell me how can I open the remote control to replace the bateries, since i lost the literature. My name : NANDO
Jul 25, 2011 | Danby Heating & Cooling
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
I've got a Danby DPAC 8399-4 portable heater/air conditioner. We usually use it as an A/C but we're trying to use the heater for the winter; we just brought it out of the closet. The fan barely works (and...
Check for obstructuions in the fan housing that may be hitting the fan blade, causing the noise and improper air flow.
Improper air flow will cause the uniot to overheat quickly and it will shut down on its high temperature limit switch.
You may also have a bad fan. Bad bearings will make a bad noise as well. Thios will cause the same symptoms described above.
Check for abstructions, if you can find one, remove it, if not replace the fan. You can usually reset the limit by simply turning off power and turning it back on after 10 min.
Dec 06, 2008 | Danby DPAC8399 Air Conditioner
Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Jul 08, 2008 | LG Goldstar GWHD5000 wall/window Air...
Dark laptop display
Well if youve already replaced both of those items with ones you know work then the last thing you can do is replace the LCD Cable
Aug 23, 2007 | HP Compaq nc6220 Notebook
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
