My washer will work till it hits the spin cycle and then it stops can you help me
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Please list Brand and Model number. Pumps water out, but no spin? Making any noise?
  • Washing Mach... Master
  • 1,527 Answers
Hello there could be 2 things that could be wrong 1 it could be the module board this controls the spin cycle the other could be the programmer you need to check both good luck
shaun
Posted on Jul 27, 2009
My maytag neptune tl stops after wash cycle it will start for a few secounds then stops and will continue this start stop action till i hit the stop button
The washer is trying to go into spin but failing. The two sprag clutches are probably sticking, This usually indicates a water leak.
The seal should be replaced. The bearing and sprag clutches should also be checked and will probably need to be relubricate or replaced.
Apr 15, 2016 | Maytag Neptune FAV6800AW Top Load Washer
Why does my washer stop after the rinse cycle and doesn't advance to the spin cycle?
only a guess but sounds like the control board or the timer is going bad .stating make and model usually helps
Feb 02, 2016 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Our Kenmore Washer stops running when it hits the spin cycle. All the other cycles seem to work but at the spin cycle it stops.
Check you door switch. Most of the time this is the cause for this condition. What is the model number of your Kenmore?
Nov 28, 2010 | Kenmore Washing Machines
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't stop spinning
i am a recently retired appliance engineer of 20 years, if the fault is not right after he has called then write to the manager of the company, if he is sole operator then write to him, explaining it like you said above, ask that the engineer stay and watch till the very end of the cycle as thats where the fault is, if he has already worked on the machine fetch them back? alternatively just ask a different engineer who knows what he is on about, to me this sounds like a circuit board problem either the timer or main pcb module, i presume this is a computer control washer with a digital display, hope this has helped you at least as to where to start, thank you.
Sep 13, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
Top Washing Machines Experts
