Question about The Computers & Internet
How do you get a stuck sd card out of a tablet
When it unmounts it does not come out of the slot it went into
  • 44 Answers
Have you tried pushing in on the card? That typically releases the lock and allows it to pop-out. You'll hear a small click and see the card extend outward if that is the way yours works (as most do). Then pinch with your fingers or even finger nails if small and remove.
Posted on Aug 10, 2017
The Machine
  • 788 Answers
SOURCE: SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Posted on Jan 18, 2008
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP ( and you are set. 16GB SDHC working like a charm.
Posted on May 14, 2008
  • 32281 Answers
SOURCE: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Posted on Aug 14, 2009
SOURCE: sd card in cd slot of imac desktop
Use a large paper clip and fold it shaped. Gently insert it into the cd slot and drag the card out. My kid has done it twice so far. Make sure the power is off and if the clip hangs, don't pull.
Posted on Feb 19, 2010
Testimonial: "can't get a hold of anything, still trying thanks!"
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
My phone says SD card is unmounted when its mounted. I have tried another SD card and it still says its unmounted what can I do to fix it. My phone is a Kyrocera.
is your card accessible? Im betting its a bent pin in the card slot. You may be able to use a dental pick (very thin strong metal pick) to gently pull the pins down ever so slightly to make contact with the card again. Sometimes gluing a tiny piece of foil over the card contact helps reach the bent card contact but thats assuming your phone is unrepairable and you dont have the money for a new one.
Aug 18, 2015 | Cell Phones
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
How do i get my micro sd card out of the slot on my asus memo pad, its stuck and i cant see it
The card reader slot is shorter than the memory card itself, so it sounds like you didn't put the SD card into the card reader but rather, into some other kind of slot. If you cannot see the card at all, try straightening a wire such as a large paperclip or something and try using a flashlight so you can see to try and fish the SD card out. If you can't do it, you will have to go to the local computer store for them to try for you.
Apr 26, 2015 | ASUS MeMO Pad HD 7
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
How do l mount a sd card on my zeki tablet TBDG734B
Mounting is done automatically by the device in most
Android tablets.
For an Android, all you have to do is insert the SD card in the slot and it will be mounted automatically. If you want to remove the card, though, you need to *unmount* it. You can unmount in Settings>Storage>External SD card and will see the unmount option listed below it. Touch it and then you can remove your SD card without the possibility of corrupting the files.
Apr 17, 2015 | Tablets & eReaders
I inerted a 32gb SD card and nothing happened so I popped it out anthem I could not get it to pop ck in tablet said new SD card???
When you insert an SD card in the slot the tablet will *mount* it automatically. This means it connects to it and formats it and adds some files and folders so it can utilize it.
Before you remove it you need to go to Settings>Storage>External SD and touch the *unmount* option.
If you don't do this there is a chance the card can be corrupted and can become unusable. If the tablet said new SD card then you might have to go into Settings>Storage>External SD and touch the *Mount* option.
If it's a new SD card chances are you didn't hurt it. But if it's a use one on which you had a lot of data stored and you didn't unmount it before removing it you could have damaged the file structure and your only option to get it back would be to put it into a card reader on a laptop or desktop and reformat it.
Apr 14, 2015 | Dragon Touch Touch R10 10.1 Google Android...
How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Jan 11, 2015 | Tablets & eReaders
How do I add an sd card to my prontotec axius?
Insert the SD card into the SD card slot on side of Tablet the correct way round. Taking note of the angled side of the card in relation to the diagram on the Tablet case. Start Tablet, go to settings, storage, scroll down to SD card & mount the card. Once the card is mounted it's ready to use. Remember to unmount the card before removal to reduce the risk of data loss. Hope this helps. Regards Bob
Jul 27, 2014 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
Sd card corruption
You may have fried the bios on the SD cart! If so you can't retrieve it!
Jan 01, 2013 | Coby Kyros 7" Touchscreen Tablet
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
