Question about Radio Communications
Lost most of the channels How do I get them back from my Dx-rcoa-12
Cobra 200 gtl dx only does 12 watts on high
Open radio up and adjust rv9for am fm high power or rv 14 for ssb for high power,do not use a screwdriver,a matchstick would be better.board information is available from cb
Dec 17, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Wiring a power
get a 12 volt 3 to 10 amp power supply. radio Shack has many. Red(+) is 12 volt + hot..Black and metal is always ground(-).
Apr 11, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
What should lite up on this radio, on mine just the channel number lites up. Is that right ? Thank you for your time.
The meter and the channel indicator should light up. You can purchase a 12 volt wheat lamp at Radio Shack to replace the burned out bulb in the meter. Dont know how technical you are, but, those lights are pretty easy to change. Just follow the wires that lead to the meter. There will be 2 sets. One that solder to two little tabs on the back of the meter (these control the needle movement) and another set that lead to the bulb. The bulb basically just slides into a little square hole in the side/back of the meter. Good luck. Hope this helped. Lost Jeep, Athens GA, 10-7 !!
Feb 17, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
