Question about Garden
Are there an service manuals for tuff torq transmissions ? The only google hits I get are youtube and scam/misleading links. I am looking for a manual for a K46, ideally the DF variant
3 Suggested Answers
SOURCE: Toshiba Dp3580 service manual
endlock which place can buy.i am singapore. what is end block . ok thanks by.asap.
Posted on Dec 29, 2008
  • 2678 Answers
SOURCE: hp photosmart c7180 SERVICE manual.
Do you really thin HP will release them to the public?
Posted on Jul 30, 2009
I put a new drive belt on my la 175 jonh ddeere mower but its still when it get hot
hydraulic transmission is going out. you may get some additional life out of it by changing the tranny oil.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
http://tufftorq.com/products/lawn-garden/index.html
Tuff Torq Lawn Garden
May 21, 2015 | Garden
Oil type in hydro tranny
Owner's manual, no manual, try MFG website, or email their customer service, or try manualslib.com
Apr 14, 2015 | Garden
How do I change the hydraulic fluid?
Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
Apr 11, 2015 | Garden
I HAVE A CTH140 TWIN LAWN TRACTOR AND WOULD LOVE SOME GUIDANCE ON CHANGING/TOPPING UP OIL IN TRANSAXLE, CANT FIND A FILLER PORT OR EMPTY PORT, ND WHAT OIL SHOULD I USE.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process. Tuff Torq Lawn Garden
Apr 08, 2015 | Garden
HOW DO I CHANGE/TOP UP OIL IN TRANSAXLE...WHAT OIL?
The best lawn tractor Hydrostatic Transmission Fluid isactually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Diagram for hydrostatic drive
Apr 07, 2015 | Garden
How do I check the transmission fluid level in a Cox Kingcat ride on mower What grade do I use to top it up
Depends if your has an external expansion or not. Normally you do don't need to check these transaxles as they are considered sealed units but if you wish to do so the following is the two documents from Tuff Torq on how do it.
K46 OIL 1
CAO46 External
Dec 11, 2014 | Garden
Info on repairing transmission, install belts
This transmission will be a Tuff Torq K46 series. You will need to look along the transmission's drive axle housing to get the model number. From there you can look-up the parts at Tuff Torq website under their catalog page. There is no service manuals that I know of but I did find a discussion on .tractorbynet.com about repairing the K46 that has pics. See links below:
Tuff Torq Parts Look-ups
Tuff Torq K46 Repair Guide with Pictures
As belt installation Searspartsdirect.com will have the IPL for the mower.
Nov 14, 2014 | Garden
How does a hydro static transmission work
The Hydro-Static transmission is a hydraulic pump. I have added a link for Tuff Torq. They have videos showing how this type of transaxle works. Very cool video.
http://www.tufftorq.com/
Jul 07, 2014 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Tuff torq k51
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/Troubleshooting/Diagnostic_Flowchart_EN_23DEC08.pdf Hey, check out the manufacturers trouble shooting chart. This is a hydrostatic not a geared transmission right?
Apr 09, 2014 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
