Question about Wahl Health & Beauty
How do I replace the blades on a Wahl model 550 Sterling ref.Senior hair clipper
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
rick_stokes_
  • 61 Answers
SOURCE: loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Posted on Sep 27, 2009
philschneide
  • 448 Answers
SOURCE: Noisy wahl hair clippers
If your clippers are the magnetic type (rather than pivot or rotary) they should have a large screw on the side for adjustment (I think the screw you mentioned). The standard adjustment of the screw is to turn it in while the clipper is running until the sound of the clipper increases substantially. Then turn the screw back out, slowly, until the sound decreases again. Turn another 1/4 to 1/2 turn.
Unless something else is wrong, this should take care of the problem, along with proper oiling of the blades.
I hope this helps you.
Posted on Oct 12, 2009
brector3
  • 1612 Answers
SOURCE: The clipper blade adjustment on my Remington Hair
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Posted on Jan 26, 2010
Testimonial: "Thanks "
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
How to fix my wahl senior so it doesn't pull hair
It could be one of several problems, but the most likely problem is that the blade is too far back. There are two adjustment screws on the the blade -- loosen these a tiny bit, then slide the blade forward (away from the clipper) and then tighten the screws again.
Nov 23, 2011 | Andis 01690 Hair Trimmer
I need a replacement cord. It no longer makes a connection. The clippers are otherwise in good shape.
contact mannyssharpening@yahoo.com They are a Wahl Clipper Dealer they have the All Wahl Parts
Oct 20, 2009 | Wahl Sterling Shadow 8745 Hair Trimmer
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
Health & Beauty Logo
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
