Question about Roper Dryers
I have a Roper dryer model REX5634KQ1 and I am trying to determine what size it is as I need to buy a new dryer
yalmer
  • 549 Answers
SOURCE: I have a Roper REX5634KQ1
Check to see if there is power coming to the outlet that it is plugged into.
It sounds like a fuse blew when you changed the light.
Maybe there is something wrong with the socket or the bulb you put in is bad.
If lyou have power to the dryer, then you must have a bad door switch etc.
Posted on Mar 22, 2008
  • 105 Answers
SOURCE: I have a Roper Dryer Mod# REX5634KQ1. It just
There is a "one shot " thermostat that is probably blown. Part number 279816 which is a two piece kit. The part is located at the top of the heater housing.
Posted on Apr 07, 2009
  • 659 Answers
SOURCE: I bought a new property
Roper is made by Whirlpool. The Roper website is down and under construction. Contact Whirlpool either by email or telephone. They may be able to give you the info you are looking for.
http://www.whirlpool.com/custserv/index.jsp
Posted on Apr 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Posted on Oct 06, 2009
  • 249 Answers
SOURCE: roper model rex5634kq1----won't get hot---already
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 01, 2010
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
What is the capacity of Roper dryer REX5634KQ1, we received it in trade from my daughter's home and have no manual
While i am not sure it states the capicity here is a link to download the manual
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203978913.pdf
Pretty much it will have a capicity that will handle a normal non overloaded washer
Gene
Aug 14, 2011 | Roper REX5635E Dryer
My Roper REX5634KQ1 will not start. I finished a load and when i put the next in it would not start. I have checked the braker box and it is still on, I cleaned lint from the back and checked for any...
there is a onetime fuse in the back that burns out and the dryer will not stsrt until you replace it is small white fuse with 2 wires attached
Sep 21, 2010 | Roper REX5635E Dryer
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Roper Dryers
My dryer will not shut off.
You need to replace your door switch.
Mar 05, 2010 | Dryers
I have a roper REX5634KQ1 won't turn on!
Thermal fuse is the problem , located on the blower housing . (small white thin piece with 2 wires attached ) Pt# 3392519 . You will have to remove the front panel to get to it .
Jul 13, 2009 | Dryers
Apr 07, 2009 | Roper REX5635E Dryer
Mar 22, 2008 | Roper RGX5635E Dryer
Dryers Logo
32 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
