Power on button no longer functions. Is this a self fix problem? It had been irregular for a couple of weeks, and now does not function at all.Is this a self fix? Instructions? Thanks in advance.
  • viejoleg Jul 28, 2009
    Site form refused to accept type of laptop. It is an HP T23 notebook. Initially the machine would on occasion only spin the hard drive and fan upon pressing, with repeat requests, finally working. Then It would not connect at all, just spin. Now nothing.
    I will try your suggestion. Thank you.
  • jk_10_79 May 11, 2010
    What kind of laptop is it? If the rest of the laptop seems to work fine it may just be a problem with the button itself. Look for instructions on how to disassemble your laptop properly until you can view how the power button connects to the motherboard.
  • 724 Answers
Can you get to the processor and reseat it? Sounds like your cooling fan malfuntioned and you did not notice it because it is to silent...and overheated see if you can reserrect it that way. worth a try you can not break a broken thing
Posted on Jul 27, 2009
Camera shuts off when shutter button is pressed.
I'd try replacing the battery first. It is common for a low power battery to not allow the camera's computer to read what it is supposed to do correctly. If the new fully charged battery doesn't fix it, I'd then contact customer service.
Apr 29, 2015 | Canon PowerShot S2 IS Digital Camera
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Rounding function on my TI-30xIIs calculator, it won't turn off.
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
Apr 16, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
TV wont turn on
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Aug 20, 2008 | Sony KP-41T65 41" Rear Projection...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
