Question about Radio Communications
Does anyone have a programming file for an Icom u16 radio preferably to work on Windows Ten
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: icom m402
you may have poor connections on you LCD screen leads. I would first determine if the blinking is being caused by a loose connection or by something happening within the CB circuitry. The best way to do this would be to try to push and hold the LCD screen to stop the blinking if this works then your trouble is a loose connection. If it does not work then you may have some kind of internal problem. One such problem would the the IC driving the LCD screen you will need to have a schematic to troubleshoot this. The schematic will show you the voltage readings that should be on the pins of the LCD driver IC, and by measuring the voltages you should be able to determine which components are defective. You may also want to use a logic probe if the schematic contains a truth table of the states the pins sould be in under test conditions.
Posted on Sep 05, 2007
Icom u16 Rx , but when I Tx , speaker makes buzzing noise , could the antenna connection to the pc board be bad ?
It's possible because this would allow the RF signal to flood the circuit. I would suggest you try another antenna as a first solution. A bad antenna would cause the same problem. Good luck and let me know if it helps!
Sep 18, 2013 | ICOM Informatique Icom Radio U16, IC2GAT,...
Icom f33gs programming problems
check port setting and on/off your radio then try to read or write.
May 12, 2013 | Icom IC-F33GS Programming Cable USA Shop
Program manuals ic-h16
  • When you get to the link click on "Click here to start download from MediaFire.." and it will download onto your PC.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Radio Communications
To RESET all programs Frequencies on my IC-H16 portable radio.
You can download and review the manual for the Icom IC-H16/U16/U2 HT here. This radio is an Amateur Radio Service transceiver, and will require an FCC license to transmit. No license is required to monitor or listen to the radio. Keep in mind, the Amateur Radio Service is NOT part of "CB" or "FRS" radio services - neither of which require a license to transmit.
When you read the manual, you'll quickly see that there is no "reset" function available. There are only 16 memory locations, so you can simply lock out channels you no longer wish to monitor or you may program any valid frequency in the range supported by the radio. Doing this, in combination with setting the squelch or tone will prevent the radio from opening a particular frequency(s) when the corresponding memory location is scanned.
I hope this helps and good luck.
May 04, 2011 | Motorola GPS
Manual for ic h16
You can download and print your manual, at no cost, here:
http://www.repeater-builder.com/icom/pdfs/icom-ic-u2-h16-u16-user-man.pdf
Bill B
Aug 06, 2010 | Icom Radio Communications
How do i program my icom IC-F3GS what program do i ned
I use the ICOM OPC-478 cable along with the ICOM F3GS software. In order to use the OPC-478 cable with WINDOWS 7, it will be necessary to go to the site
www.icomamerica.com
choose support (not option 1) and look for the updated driver package for WINDOWS 7. When that has been downloaded and installed, it will be necessary to go into that part of the control device manager and change the port to "COM2".
I am now able to program both my IC-F3GS and the IC-F4GS.
Sep 23, 2009 | ICOM Informatique iTECH iQfive iQplus Icom...
Miland 70-154
http://www.scribd.com/doc/11188457/MIdland-70154254-Icom-ICUV16-programming
http://www.retrevo.com/s/ICOM-IC-2GXET-review-manual/id/559bh834/t/1-2/
Jan 25, 2009 | Midland Radio 70-154 Compatible Battery
Memory program ch no# on icom u or h16
I had the same problem. I solved it by going into program mode, then while holding down the function key, input one of the missing channel numbers. The channel should appear but is flashing. Now input a frequency for the channel and exit program mode. Repeat the sequence for the other missing channels. This procedure worked for me. Good luck.
Nov 19, 2008 | ICOM Informatique Icom Radio U16, IC2GAT,...
ICOM F43TR
Chris, How is it that you programmed your radio. Do you have the software for this radio? if so please send me a copy of the saved radio file so that I can make sure that all the settings are correct.
Pat
vrc-repair@sbcglobal.net
Jul 28, 2008 | ICOM Informatique Icom Radio U16, IC2GAT,...
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
