Question about Refrigerators
Door to ice maker wont open - Refrigerators
  • 175 Answers
SOURCE: No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Posted on Dec 17, 2006
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at
Posted on Oct 21, 2007
SOURCE: ice door opener
GE side x side GSS22SGMC stainless steelJust fixed my own problem of jammed ice door. 1. pull the light switch plate off (just under the front bottom edge, push through the holes, pull) 2. unscrew the dispenser assembly, 4 screws, pull the unit out  3. WR62X10020 SOLENOID is in the upper right, unplug the black wires from the board. 4. unscrew the right screw from the door-stop assembly (above the ice door)- pull the plastic out of the solenoid piston 4. unscrew solenoid, 3 screws, from back 5. pull the piston, scrape-sand-file off all rust, then lube with oil 6. scrape off rust from inside,  solenoid with shoving steel wool-file-degreaser to get off rust, then lube 7. reassemble, WORKS!! 8. save 35.00 for new solenoid 9. save repair cost of whole new door (happened!) good luck
Posted on Apr 29, 2008
SOURCE: flapper door that dispenses ice will not open automatically
the flapper door appears to be broken. how can it be repaired?
Posted on Nov 29, 2008
  • 161 Answers
SOURCE: Maytag MCD2257KES ice maker shoot door does not open
Yes, the ice/water unit can be removed from the door to give access to the switch and solenoid that opens the ice door.
Posted on Dec 28, 2008
Ice maker on/off light?
ice bucket full and/or door open so ice maker does not dump ice when you have door open.
Apr 04, 2014 | Refrigerators
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Could be an open circuit to the ice tray sensor. This is the wire under the ice tray. It is flexed during each cycle and can fatigue easily. I found this condition on a three year old unit. A simple solder repair and heat shrink tube corrected the problem.
Jul 26, 2012 | LG LFX25971ST Bottom Freezer French Door...
Unplugged, Then allow 1 or up to 5 hour then open, if not get screw to open the compartment door. check all side of the compartment door. avoid so much full content to your ice maker refrigerator, and always give a free space to the compartment door.
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
Jun 06, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker makes ice but doesnt kick it out
seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker frezing at storage tray and door will not let ice in shoot
This is generally caused by one or two things (sometimes a combination of both).
1.) If it is a "frost Free" freezer the mechanism that partially thaws the freezer has stopped being regulated and will require professional repair.
2.) The door gasket may be bad, causing a small amount of warm air to reach the ice and then it is refreezing in a blob.
another cause is: if you constantly open the freezer door or hold it open for long periods of time while searching for items etc. the ice lightly skims with moisture then refreezes into a blob.
Aug 16, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
