Need cod for rca sta 3850 using RCA RCRN06GR remout
025,022,029,021. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box. Check this link too.
May 17, 2014 | Televison & Video
Need to buy a remote for eq3402
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 13, 2013 | LG Lsb316 280w Sound Bar Wireless...
KEY LOCK this lockkeys on set. Set can be operate with remout control.Please how do you remove key lock i have no instruction book. Thanks Dave
On some units going to the lock setting in the menu and input all zeros will reset it. Would need make and model number to get proper method of resetting the lock.
Jun 26, 2009 | Toshiba 32WLT58 32 in. LCD Television
Start problem
The remote is not working properly. If possible get the remote serviced at any authorized center & if not serviceable you have no option but to replace the set with a compatible set.......sodeep
(but before you do that if the remote has batteries and they have been in use for quite some time then change those batteries & give it a trial)
May 24, 2009 | 2008 BMW 1 Series
If you just purchase a new universal remote control. You need the manual that came with remote. Inside you should be able to find your brand of DVD player and the codes to activate it. Since all Universal Remotes are different there's no set procedure that will work for all of them. You will need the manual and go through each step to set up correctly. If you don't have or misplaced manual, you might need to contact manufacturer to either replace manual or receive the codes. Good Luck
Oct 19, 2008 | Philips DVDR610 DVD Recorder
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
