Question about Murray Garden
I need a manual for a 29" Murray snowthrower.
The drive stopped working. It won't move forward or backwards.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Murray Master
  • 1,419 Answers
Try Parts Tree .com they may help
Posted on Feb 07, 2018
  • 49 Answers
SOURCE: The electric front seats both stopped moving
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
Posted on Aug 21, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
suzukiracing
  • 200 Answers
SOURCE: won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
SOURCE: power seat won't move backwards
I had the same problem some one on one of the web-sites solved his problem by banging on the track rail in the front while pushing the seat button back after a good few bangs it unjamed and works great now .I feel like I saved at least $1500 by dealer rates.
Posted on Aug 19, 2010
juliefarley
  • 17 Answers
SOURCE: 24 hp LA165 mower. While mowing
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Posted on Jul 18, 2011
My murray riding lawn mower stops moving in forward and very slow in reverse after about 20 minutes of mowing.
the balts are probably wore out. if they look cracked or thin in spots replace them both at the same time. should be back to new.
Jul 09, 2016 | Murray Garden
How do I fix my snowthrower which is not going forward or backward sometimes when the gear lever is positioned properly?
Hi Patrick,
Most "walk behind" snowthrowers / blowers have simple mechanical transmissions. No fluids like you would find in a car or truck. You posted in a riding tractor category - so I don't know exactly what you have.
If the fluid is slippery, and dripping on the disc or drive wheel that tracks on the disc, it is just slipping. Open the compartment under the machine to find and stop the source of the drip. Thoroughly clean the disk and wheel, reassemble and you should have forward and reverse again.
Feb 10, 2015 | Light Garden
Murray 42" tractor drive won't engage
Does the wheel you took off only have one centre nut?
If so it whould appear that you may not have put the key in the keyway of the shaft and the wheel when you put it back on. Maybe the key was in the wheel and hs fallen out at the repairers.
Sep 28, 2017 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Won,t move
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
My Yardsman Snowthrower will not move when it is put in gear.
My old machine just did the same thing. When I lift the unit off the wheels with the gear engaged the wheels move. when I put it down the machine doesn't move. This happened while I was using the machine. BTW the machine is 20 years old.
Dec 31, 2009 | Mtd Products Yard Machines 158CC Tiller
Jun 22, 2009 | Garden
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
