SOURCE: Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid
10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
SOURCE: my remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Try Vance Baldwin a parts dist in florida
the handle Polaroid tv's
