Question about RCA Lands Phones
My rca cordless phone says searching all the time what does this mean?
3 Suggested Answers
Schmead10
  • 650 Answers
SOURCE: I cannont register a ATT 2042 cordless phone to
Are you sure it's a 2042...I found 2402 manual http://www.retrevo.com/samples/AT%26T-Telephone-manuals.html
Posted on Apr 14, 2009
  • 3289 Answers
SOURCE: what does it mean when it says searching on my cordless phone
This usually indicates that the handset is having a problem establishing a wireless connection with the base unit.
Try placing the affected handset in the base charging cradle for a few seconds to let them sync to each other. Remove the handset and try again. If you are able to use the phone again, but only within a few feet of the base, there is probably an issue with the radio or antenna in the handset (assuming all other handset works fine). If all associated wireless handsets have the same scanning message and only work close to the base, then the problem is likely with the radio or antenna in the base, instead. You may be able to see a loose or broken connection if you wish to dig around - but if there's nothing obvious - you're probably better off leaving it alone and obtaining a replacement instead. Before beginning - be sure to unplug the AC power and telephone wire from the base and the remove the battery from the handsets.
Without a specific model number for your phone, only a generic solution can be provided. There may or may not be additional suggestions to help you solve the problem if you provide the Uniden model number.
Posted on Jan 09, 2012
How do I fix a rca 6.0 cordless phone which has a blank screen but phone works
Most likely you cannot. The screen is either damaged or the display drivers are bad.
Oct 08, 2015 | RCA 25211 2-Line Dect 6.0 Cordless Phone...
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
May 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
I have a 3 pack of cordless Uniden Dect 6.0 phones, my phones were all working properly, now they are not. All 3 of the phones say searching on the screens and they all have a blinking red light on them.
hi that means for you to check the connect of the phones and make sure they are all plug in if this does not work take them to a company near you that repairs cordless phones..
Jun 12, 2011 | Uniden DECT 6.0 Cordless Telephone...
Why do all three of the cordless phones (the base phone and two handsets) make a clicking noise?
I am not sure what clicking noise you mean, but if it is constant clicking in the earpiece about once or twice a second it may be interference from a nearby wireless device such as a laptop or microwave, or a wireless router. Try moving the base station away from any such objects.
Mar 01, 2011 | RCA 25255RE1 2Line Cordless Expansion...
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
RCA 900 MHz Accessory Handset- H5400RE3 for 4-line systems 25413RE3, 25414RE3 & 25415RE3
Donna75603,
Go near the base of the corded phone to register your cordless phone. Press "menu" on your cordless phone and press arrow key till you see "Registration". Press "Select" key. The sreen will show "Yes" and "No" sign. Press arrow key once to select "Yes" then press "Select" key. The sreeen will show "Registerring.." , at this time press "Page" key on the corded or base phone and hold it for a few seconds until you hear a beeping sound. This is the sign the the phones are syncronized. You can now use your cordless phone.
Jun
Brooklyn
May 14, 2008 | RCA Lands Phones
Phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
RCA 25110RE3-A cordless headset
Mine was doing the same and I just pressed the "find" button on the wall plug in thing- and the headset started working....you may want to try that.....?????
Dec 31, 2007 | RCA 25110RE3 Phone
GE 27831 Cordless - Date Time Issue
should be in the main menu thru the handset setup .unlike cell phones that reset automatically . you must go into setup and do it
Dec 23, 2017 | GE 27831 Cordless Phone
Lands Phones Logo
75 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
