Question about Refrigerators
My ice craft fridge is not cooling down its been working fine for over a year .the heating element is getting hot but fridge is not cooling down
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 360 Answers
SOURCE: Maytag MDBH970AWS Heating element won't turn off
The heater relay is located on the control board, a faulty relay or a faulty control board would cause the problem you have described. The fix is to replace the control board. Parts for your unit should be available from most appliance parts retailers, if there is not one local to you, the part is available at along with an exploded view of your unit
Hope this helps.
please take the time to rate this solution
Posted on Mar 05, 2009
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Posted on May 17, 2009
  • 1218 Answers
SOURCE: Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Posted on Jul 08, 2010
Testimonial: "Thank for your advice. This answers a number of questions. However I don't understand the last sentence. Could you clarify? Thanks again!"
LG FX28977ST the freezer only gets down to 32 degrees and the refrigerator only gets down to 43 degrees. It seemed to work fine until two days ago when it quit making ice and the ice cream got soft.
First, I'm not a LG Technician. Call your LG vendor for service.
*** the following is for information only. ***
* Move food items to another refrigerator.
* Do a complete DEFROST of the box. (unplug it.) Expect it to take 4 or more hours. You must wait till all water stops dripping out of the fridge. Keep checking the lower defrost drip tray at bottom of fridge. Dump out water from tray as needed. DO NOT you a hair drier or any other heat source! The heat will warp the plastic. Use a small fan to gently blow into the freezer section.
* DO NOT use an ice pick or sharp object to remove ice! Just let everything melt. (The problem of ice is inside the coils)
* Plug in Fridge but don't put any food in. Set dial temperature to the Mid range setting. Set to freezer venting to normal. Set the refrigerator to mid range. Let it cool down to 0 - 10 degrees and start making ice (in ice maker) If it does not cool down to at least 10 degrees F then call for service. Suspect bad thermostat, Blocked condenser coils, Bad pump, etc. Qualified service tech required to repair.
* Cooling okay? Reload food but don't stuff it in. Leave space between the walls to allow cold air to flow around foods. It will take a day or so to cool down food properly. Note: I may take longer if this fridge is near a heat source like a Hot water heater, Oven, Range, Steam radiator, etc.
* If your still icing up in 2-3 weeks. Then check if the coils are icing up. Defrost is not working. This needs to be checked by a tech. Have him perform annual maintenance.
* Check door seals. Kids leaving the door open? High humidity? * Note how everyone uses the fridge; are they putting hot food in it? Open hot steaming food adds heat and humidity to fridge. Hot food with thaw out other frozen food and build up frost.
* Final, Have a Tech check your fridge. Have them perform maintenance and replace worn items as needed.
Aloha, ukeboy57
Mar 12, 2018 | LG Refrigerators
Msd2756de fridge side wont cool
all of the above solutions are correct evaporator fan going bad causing the ice to build up defrost timer getting stuck or heating element for defrost not working...good luck
Mar 16, 2014 | Maytag MSD2756G Side by Side Refrigerator
I have a dometic 2193. It will not cool down at all.
if hot replace cooling unit or thermistor if not hot heater element
Sep 05, 2012 | Dometic RM2193 Compact Refrigerator With...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
Kenmore refrigerator,bottom stoped cooling.freezer works just a little bit.8 years old.bought new.
More than likely your freezer has a ice block in it it will have a lot of frost on the inside of the freezer. This ice block is usually caused by a bad timer or a bad heating element in the freezer. The timer kicks in a timed cycle to turn on the heating element and a hi heat limit keeps it from getting to hot just hot enough to melt any frost and ice. (thats how we have frost free fridges now)
Aug 12, 2010 | Kenmore Refrigerators
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
No Cooling in the Fridge section, freezer is icing
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Jun 03, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
