NEED DIAGRAM FOR TV TO VCR RECORDING - Televison & Video
4 Suggested Answers
  • 6 Answers
SOURCE: unable to connect philips dvd
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Posted on Mar 31, 2008
  • 8 Answers
SOURCE: connections, security camara/vcr/tv
A VCR uses a "RF" signal, where a TV uses a broadcast signal. The standard TV will not record from a security VCR. However, if the TV has a yellow "video in" jack on the back, this will work to record the VCR. You might need to buy a BNC to RCA adaptor at radio shack. Let me know if this does not work.
steven.burman@commandtechnologyassociates.com
Posted on Nov 26, 2008
djicenova
  • 319 Answers
SOURCE: Connecting a VCR and DVD recorder to the TV
from what type of source are you doing this? if its CATV with NO BOX, i can help.
Here is a rough sketch:
use COAXIAL cable from splitter to VCR and TV and to the RF Modulator (get one at radio shack) from the RF Mod, to DVD, use RCA cables. Run RCA Cable from output DVD to Input on the TV. Run RCA cables from your VCR output to another TV Input
PLEASE RATE ME WELL if you find this useful!!!!!!!!!
Posted on Feb 27, 2009
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Feb 27, 2009 | Panasonic DMRES20D DVD Recorder
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Connections, security camara/vcr/tv
Nov 25, 2008 | Home Security
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
Nov 22, 2008 | Kenwood KR-V7080 Receiver
Motorola 700 digital cable receiver
unless you have a tv with picture in picture you cannot record one ch and record another.
Thanks Guy9
Jun 18, 2008 | Televison & Video
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
