We bought a mean machine rc baja dune buggy car made in 2015 .the remote control had a small blak piece fall out of it and now it will not turn the car.Could we get a new controll
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
ginko
  • 19396 Answers
SOURCE: Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
Posted on Apr 18, 2009
SOURCE: Code RC 1 displays when I use my Sharp Blu Ray
Setting the Remote Control Code of the Player: Point the remote control at the DISPLAY button.
The display on the player changes as shown below, and the player will be set to the smae number as the remote control.
or
Press and hold 1 first and then POWER on the memote control together for more than 5 seconds.
Posted on Aug 21, 2009
  • 65 Answers
SOURCE: tamiya hornet steers/moves in opposite dierctions
turn your servos around
Posted on Mar 30, 2010
  • 29 Answers
SOURCE: Buggy is removing charge from battery
try investing in a battery charger instead of replacing the battery the dune buggy probably doesn't have an altinater to recharge the battery
Posted on Apr 20, 2010
Remote not working throttle or steering ,and remote keeps saying low battery but has brand new batteries
FAQ - Answers for Common Redcat RC Questions
www.redcatracing.com/FAQ
Q. I installed batteries in my car and in the remote control but when I turn on the power ... You may have some things such as throttle working but no steering. ... If it doesn"t your cord may have come off track and you can simply open the rear of ...
Why is my remote control not working? - Geardup RC Ford ...
https://www.ifixit.com/.../Why+is+my+remote+control+not+workin...
iFixitFeb 19, 2015 - To fix this, you can replace the batteries. ... The GEAR'D UP RC Ford Mustang GT is a remote controlled car released ... Is this a good question?
Troubleshooting an RC That Won't Run - Radio Controlled ...rcvehicles.about.com > ... > Troubleshooting, Repair, and MaintenanceRadio Controlled Vehicles Expert. Share ... The batteries are often at the root of manyRC problems. ... Loose or broken wires can result in a host of problems.Radio Control FAQ ' RC Toys ' New Bright
Dec 25, 2015 | Exceed-RC RC Truck
Two of the remote control cars we bought are broken
Sorry but these are very cheap and no parts are made for repair.
May 05, 2017 | RC Thunder Tumbler Rc Car
Razor Dune Buggy Problem
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
Jul 23, 2012 | Razor USA Razor Dune Buggy
Apr 18, 2010 | Jeep 36 Volt Battery for Minimoto ATV, Go...
ShengQi Baja Buggy
had same problem on mine,could not work out why it kept dying out when warmed up. i found that if you open fuel tank cap when tank was half full and let air in it seems to do trick. hope this helps...gaz
Jan 02, 2010 | Cars & Co Remote Controlled Car
I need a transmitter for a radio shack rc car - golden arrow frame buggy model 60-4080
have look inside car to see what frequancy its on. crystal will be soldered to a circuit board, if unsure what looks like have look on ebay. once you kow frequancy you can buy crystal and transmitter quiet cheap on ebay.
Oct 11, 2009 | Cars & Co Remote Controlled Car
Unknown make of engine
generally the dune buggy was made by a volkswagen chassis and engines
Apr 15, 2009 | 2006 Toyota Camry
Toshiba Remote control conflicts with another device
I do not know of any possible address changes that can be made but the easiest solution is to put a piece of opaque tape over the IR eye on the device you use the least, the problem being that you can no longer remotely control that device.
The next easiest is to move the secondary device out of the line of sight and then just aim the remotes at different locations.
Feb 27, 2009 | Televison & Video
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
