Question about Brother Office Equipment & Supplies
I need help in working the fax on my Brother MFC-J615W PRINTER.
Mix-it-up
  • 832 Answers
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Posted on Jan 10, 2008
Teckies
  • 226 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
ok. right click on my computer,
click on manage,
click usb ports,
delete all files named composite device.
unplug the cable from your printer
restart your computer.
plug it again the cable.
start your printer.
good luck...
Posted on Jan 23, 2008
Patrillica
  • 141 Answers
SOURCE: install Brother MFC 3100C 5in1 printer,fax,scanner,copier,pc fax to my computer.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc3100c_us
Follow this link and step 1 select driver...
step 2 select your OS....
step 3 select the language....and click search.
On the next page you'll see, in FULL DRIVER & SOFTWARE, more information, click on this and download the driver.
Posted on Apr 05, 2008
MUKHTAR
  • 2022 Answers
SOURCE: I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Posted on Mar 16, 2010
SOURCE: brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Posted on Apr 28, 2010
Will not print nor copy
sounds like you have a motherboard or controller board problem, it may cost more to repair then it would cost to replace, needs to be repaired if all the connectors are tight and plugged in
Jan 06, 2016 | Brother MFC-J615W Compact Wireless Inkjet...
Selling my MFC-J615W and need to know how to clear the memory?
http://printersquestions.com/How-to-clear-Brother-MFC-J615W-memory.html
Apr 29, 2015 | Office Equipment & Supplies
Thick black line when faxing and coping brothers ink jet model MFC-J615W
It really depends on how thick the black line is. If its say 1/2" to 1" thick then a segment of the contact image sensor has failed. If its very thin then that would be just dirt either of the scanner glasses or under them. When you open the scanner cover you will find two glasses. the thinner one is for the adf and the very large is for flat bed scanning. If you get the line when using both then the CIS is faulty and needs replacing. If either one is good with no line then it could be just the ribbon cable that goes from the main board to the CIS.
Aug 06, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
I want to hook up a printer/fax machine to my Wireless computer. HOW
check whether the wifi function of printer is on or not, there is utility of brother which searches the printer on pc after installation of the software , check it
Feb 01, 2013 | Brother Usb Cable/cord 4 Mfc-8840d...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
I need a copy of the manual of my MFC-J615W colour inkjet Multi-Function Centre
Brother MFC-J615W Manuals
Please visit the above support link for MFC-J615Wand download the required manuals which are in Adobe Acrobat (pdf) format.
Good Luck!
CreativeTECH
Mar 07, 2011 | Brother Office Equipment & Supplies
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
