Question about The Computers & Internet
Hello 9070 IR copy machine E000015 - 0000 errors. Please guide me. I also translated by the site you have to translate the sentences. So you have the goodness wording is easy. Thanks
SOURCE: Pioneer DEH-P3000IB operations manual
How to set the clock on the DEHP3000IB?
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF] (power/source button)
Pres & Hold [Muti-Control] (big button that controls volume) until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segment.
Posted on Dec 10, 2008
  • 412 Answers
SOURCE: printer message reads error 13
Error: 927 Service Fan Stalled
Check the main exhaust fan first. All models of these printers have a main exhaust fan. The main exhaust fan is located on the top of the printer, on the rear left side.
Make sure nothing has fallen down into the main exhaust fan that could be blocking it. There are vent slots/holes in the top cover of the fan, on the left-hand side. Look through these vents/holes.
If there is an item stuck there, see if you can remove it. If not, you will probably need to have a technician remove the top cover unit and extract the jammed item from the fan.
If nothing appears to be blocking the exhaust fan, power off the printer and let it sit powered off for at least a minute.
While the printer is turned off, check to see how it is plugged into the wall. It should be plugged directly into a wall outlet and not through any sort of surge device or power strip. (Power strips and uninterrupted power supplies can cause a low amperage problem in your printer, which could trigger a 927 error.) Even if it has worked on this surge device for months, try connecting the printer directly to the wall. If the printer is already plugged directly into a wall outlet, try it at a different wall outlet.
When the printer has been off for more than a minute, power it on and see if the 927 error returns.
If the 927 error does not return, try printing again. If the printer works as expected, continue using it as you were doing before the error arose. The 927 error may have been just an isolated incident. However, keep an eye on it for the next couple of days to see if the error returns.
If the 927 Fan Stall error continues to return when you power on the printer or when you try to print, the printer will probably require service.
If you are a technician working on a printer that has ONLY one fan installed, check the cable connecting the main fan to the engine/system board. Make sure the connections at the ends have not come loose and that the cable itself is not damaged. The parts that are most likely to need replacing are the main exhaust fan or the printer's engine/system board.
Some printer models also have a second auxiliary cooling fan, sometimes called the cartridge cooling fan. Printers that have this fan are the Optra T614, T616, the Lexmark T622, the T63x series (630, 632, 634) and some models of the Optra S 2420, 2450, 2455, and Se 3455. Note: The second exhaust fan was eliminated on some later models of these S series printers. The auxiliary cooling fan is located on the back of the printer, on the right-hand side.
Check the fan as you checked the main exhaust fan. Look into the vents. Make sure nothing has got stuck in this fan.
Turn the printer off and on again to see if that clears the 927 error first.
If you are a technician working on a printer with this error that has more than one fan installed, you need to establish which fan is causing the problem. You can perform the following checks:
Check the main exhaust fan first as it is usually the cause. If the main fan appears to be fine, check the cable connecting the auxiliary fan to the printer's engine/system board.
Power on the printer. During the warm-up sequence, both of these exhaust fans are supposed to turn. If one fan turns and the other does not, the fan that is not turning is the most likely cause of the problem.
Measure the voltages coming off the engine/system board to those fans. If one particular fan is not getting voltage, the problem lies with the printer's main system/engine board or that particular fan or cable.
The Lexmark T622/622n model printers also have a fan on the printhead unit. This fan is not visible from the outside of the printer, so you will not be able to check it visually. Power the printer off and on. If that does not clear the error and this fan is the cause of the problem, the printer will require service.
If you are a servicer working on this printer model, follow the steps listed above for the auxiliary fan, but adding this third fan to your list of checks for the cause of the 927 error.
Posted on Mar 09, 2009
SOURCE: HELP! Toshiba Dynabook EX Series
Posted on Jun 01, 2009
  • 1219 Answers
SOURCE: hello can somebody help me about the problem of my
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
0003 The next HP is detected earlier than the
specific period of time after the HP of
The ITB is torn due to scratches, and the
sensor detects the tear as a HP by
Posted on Jun 16, 2010
  • 2340 Answers
SOURCE: How to get rid of the Google Translate bar?
If you do not need the Google Toolbar just uninstall it from "Add/Remove" from the Control Panel.
If you want to keep Google Toolbar but don't want it to appear on your browser, Right-click the "Menu bar" and "untick/uncheck" Google Toobar. You can do the same for each individual tools too. Click on the tools the select the options and chose your choice to deselect.
Posted on Jul 30, 2010
The menu is in Spanish and I can't get it back to English
Hi Louise, I hope the google translate web page below will help, Just type OR copy and paste your sentence into the 1st section then click the arrow on the left side of the blue translate button to find the appropriate language..................CHEERS..
May 12, 2016 | Video Cameras
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Nov 07, 2014 | Office Equipment & Supplies
Ir 85 error code E000015-0000
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
Nov 19, 2012 | Canon imageRUNNER 8500 Copier
L want to translate my mail from germany to english how
Thanks for visiting FixYa!
To translate German to English, use the Bing online translator. Simply copy and paste your email messages to the translator - select from German to English - and click on, 'Translate.'
Click here:
Feb 23, 2011 | Yahoo Mail
How to change language japanese to english
I use google translate.
Enter whole sentences into translator with copy-paste
I'm not sure how you type Japanese into the translator.
Feb 18, 2011 | Cycling
I have just recieved a sliding table for my spindle moulder (TF 100 M). It came with instructions in German and French but not English! Is there anywhere online I can download the English version? Many...
I search for manuals all day ... geez, why don't these companies post their manuals? It's the digital age.
In the mean time, you need Google translate
It IS fabelhaft (fabulous, in german) >>> I just translated a timer manual written in French and Italian
One of my dang relatives is fluent in two or three languages, and she says the translator is real good, so I believe it's a winner
Type in full sentence, and the translator will handle full sentences ... no more word by word translations
Oct 15, 2010 | Garden
Gusto kung ma translate ang mga msg ko sa english
Uhmm Hello there.
for your Translation go to this site:
Just copy paste and it will just turn into english.
Sep 03, 2010 | Computers & Internet
How can I get a User's Guide for my TES-118 (I lost the original)
User's manual for the TES-118 Translator is available thru Franklin support site or just click here to download directly.
Don't forget to rate.
Dec 31, 2009 | Franklin TES-118 Translator
I have a website which is built in english, how do i translate it to french and spainish for my client?
The simplest way to translate the site will be Google language tools.
You can translate complete website and also part of it.
You will just need to select option of English to French.
If you want to translate few words then just copy paste the words in the text box available on Google Language tools.
If you want to translate your whole site then you will need to put the URL of your website in the "Translate a web page" section.
Click translate and your website will be translated.
Please note, only text will be translated and not images.
Oct 14, 2009 | Computers & Internet
Adding languages to website
Do you use MS Word 2007? If you're not looking for a professional translation, copy and paste the content or type individual words (links etc) into Word, highlight the text to translate, click Review, Translate and choose your language. As long as you use good English grammar and correct spellings, you can get a pretty reasonable translation. Just copy and paste it into your new website pages.
If you don't use Word 2007, you can also try Yahoo's Babel Fish.
However, if it's a professional translation you need, I would choose a professional translation service. You'll see some online ones listed under Word's translation. Or check out your local Chamber, Business or phone directories for translation companies.
You can also try...
Try also searching for Applied Language - Web site Translation tool 1.0.1... you can download the software from
Even if you don't use a professional translation service to translate the text, I would recommend using them to review it and correct anything that doesn't make sense.
May 11, 2009 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
