Status light "sensing" comes on but never progresses to next status.
Not sure what component might need to be replaced.
headstrong
  • 233 Answers
SOURCE: DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Posted on Jan 10, 2008
tvguy171
  • 106 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Posted on Dec 19, 2008
  • 2920 Answers
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
Posted on Feb 16, 2009
  • 3278 Answers
SOURCE: Status light is flashing
We experienced the same and needed to replace the bulb.
Posted on Jun 08, 2009
komguy
  • 2306 Answers
SOURCE: brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Posted on Feb 02, 2010
Samsung Plasma will not turn on. Status light is still on. When power button is pressed, the status light extinguishes but comes back on immediately. TV never turns on.
Hi!
I know the problem but you need a pro. Your TV does not start because there is a board defect. There are voltages to be taken at precises places but it is too technical and to dangerous you do it yourself, high voltage. I would strongly recommand you to see a pro. Good luck,
Serge.
Apr 17, 2016 | Samsung Televison & Video
I have Gigaset A490 cordless phone. Its showing Batt Empty status. No ring tone , no dial tone. I am charging it from last 2 days still the status is same. Please help!
If charger is good, you should look for replacement battery. Charger's condition might be diagnosed by any technician with a tester.
Apr 30, 2015 | Lands Phones
I have a 07' MK5 GTI and i need help figureing out why im getting absolutly no boost. ive used the vagcom reader and it threw some codes that i have no freaking clue about please help me.
so,you have Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle , Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 46-Central Conv. -- Status: Malfunction ,start by repairing these codes to figure out your boost problem
Apr 26, 2015 | Volkswagen GTI Cars & Trucks
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Yellow status light
It is doing this because the filter cover on the side of the tv has come loose, or the microswitch that senses the cover has gone bad. It is at the bottom right corner of the filter cover.
Jan 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Oct 20, 2007 | NEC LT35 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
