Question about Mitsubishi Televison & Video
Why do I have shadows on my Mitsubishi 73 inch tv
Have slowly gotten shadows kinda like halos on the entire screen notice it alot around the faces of the people on the screen how do i fix this?
sigma_shiva1
  • 188 Answers
SOURCE: Shadow around edge of monitor
yes u r wright.......u bont have a big problem..but my friend i would like to tell u that 1 of my friend was having same problem..and he did nt take care of his moniter,,,,after a few days he permantly lost his monitor .............
so i will sugest u to take care of ur s moniter...
contact u r dealer (from where u buy u r computer...)..
he can also give u any good suggesion.....
so there...thats all what i can do for u........  hope u r problem will be solved..
dont forget to tell me u r problem solved or not
best regards & best of luck..
Posted on Oct 25, 2007
SOURCE: Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Posted on Feb 07, 2008
SOURCE: Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Posted on Sep 18, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Posted on Jul 10, 2009
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
Jul 20, 2014 | Mitsubishi WD-73638 73 inch DLP 1080p...
My room mate spilled his drink and a little went on the bottom left corner. i dried up as much as possible, but now there is a dark shadow spot on the screen in the bottom left. how do i remove the screen...
liquid is never good on those screens-
there are 3 layers to the screen, from inside out, a fresnel screen (etched circle pattern), a lenticular screen (ridge lines top to bottom), and a protective screen ( "Diamond Shield" tinted plexiglass).
the fluid will wick up btween these layers, turn black, then very very slowly recede leaving a waterline mark. It can take months for it to become un-noticeable.
cleaning is possible, but beware, any type of cleaning fluid or spray is going to simulate the exact same problem but to a larger area.
also introducing dust, lint or hair into the layers when separated is almost impossible to avoid.
these pieces, especially the lenticular screen are extremely fragile nylon plastic and is apt to split under its own weight when handling, so beware the project you are about to get involved in...considering the large size.
but it can be done.
Remove all screws around the screen frame from the back of TV and the lower sides. There will be a wiring harness that goes to front buttons- disconnect it. The whole assembly will come off the front of the TV.
Lay it on the floor face down. Remove the screws in around the inside of the screen. The screens are now ready to lift out, one at a time.
IT IS IMPORTANT to not attempt this by yourself. The screen are fragile and large and scratch so easily which appear as a white opaque area when reassembled. Have a helper. Wear cotton gloves while handling as finger prints will be noticeable after you reassemble.
ALSO IMPORTANT- these screen are oriented front and back...in other words they go together in a certain direction...on each screen layer there is a small sticker on its outer edge. Make note of its orientation and reassemble accordingly.
Clean with a cotton cloth and very very little "plastic glass gleaner" (if needed only!).
WIPE EXTREMELY GENTLY in the direction of the grooves on each screen layer- much like cleaning an old vinyl record.
The lenticular screen is the biggest worry as rubbing on the grooved side is so likely to cause damage. Perhaps rubbing should be avoided if possible.
Let them lay out and dry before reassembling. A bottle of compressed air is good to remove debris when layering them back together...a dust free environment is recommended.
Reassembly and installation is just the reverse of dis assembly- remember the wiring harness connector!
Apr 13, 2011 | Mitsubishi WD-73733 73" HDTV
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
Tv will not come on. the green light on the front on the tv blinks, the blue screen come on and the tv shuts off. I've tried the reset procedure. I've unplugged the set for a while. Nothing works. The TV...
First the tv cannot be only 3 months old, (needs chassis rebuilt- send to mitsubishi they do it for around $300) and how did we go from DLP to adjusting screen levels and focus adjusment? PLEASE if you have limited knowledge you will be more helpful if you don't share it.Thanks
May 30, 2010 | Mitsubishi WD73727 73" HDTV
COLORS ARE LIKE A NEGATIVE
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
Shadow across top of screen 1-2 inches thick
I have the same problem on my Mitsubishi set. Anyone have a solution for this problem yet?
Mar 13, 2009 | Mitsubishi WD-73927 73" HDTV
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
